Loading...
Pages: [1]   Go Down
Author Topic: Arduino IDE 1.0.x - direct UART register manipulation stopped working  (Read 401 times)
Offline Offline
Newbie
View Profile
Hi guys,
I understand that the IDE has now moved away from allowing direct UART manipulation in place of Serial3.begin(speed, config) etc
I have some code which requires UART3 on a Mega 2560 to be changed to 8E1 (even parity)
The following code stopped working
Code:
UCSR3C = ( UCSR3C & ~_BV(UPM00) | _BV(UPM01) );
I have since tried to use
Code:
Serial3.begin(9600, SERIAL_8E1);
However this doesn't work. Checking my inline scanner it seems to still be using 8N1.
I'm current force to compile on an earlier IDE to get it to work.
Any insight is greatly appreciated.
Thanks in advance.
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
http://arduino.cc/forum/index.php/topic,97455.0.html
... #6, fifth bullet.
Logged
Offline Offline
Newbie
View Profile
Thanks for your reply .. but it doesn't help much smiley
Ill ask my question a different way. Has something been done / left / still to do with
A: Direct UART register maniplation such as the code I posted above
B: Has anyone got the new SerialX.begin(SPEED, SERIAL_XXX) to work correctly.
In my testing using an in-line external scanner my Arduino Mega 2560 is still transmitting 8N1 .. not 8E1 which I have been directing it to do (again see above code posted)
Thanks in advance
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
I did not even notice you could now use a second parameter in Serial.begin to specify the protocol. What version introduced this? The reference pages for Serial.begin in the 1.0.3 download do not refer to the extra protocol parameter but the on-line version does.
I do not have a Mega but after reading this thread and referring to the on-line documentation I can confirm the protocol parameter is working on a v2 UNO using 1.0.3 IDE. Below is the output. CH1 = 8N1, CH2 = 8O1 & CH3 = 8E1
« Last Edit: December 18, 2012, 07:54:42 am by Riva » Logged
Offline Offline
Newbie
View Profile
Cheers for posting that up ... very interesting.
Quick off topic question ... what software / hardware are you using for your screenshot ?
I have been compiling with 1.0.2 .. Ill try 1.0.3 to see if I can get it running.
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
I am using this little device http://www.ikalogic.com/ikalogic-products/scanalogic-2/
Quote
As I said I don't have a Mega so could not test it on the other serial ports but would assume (foolishly) they all work the same.
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Where was that announced?
Logged
Pages: [1]   Go Up
Print
Jump to:
