Loading...
Pages: [1]   Go Down
Author Topic: gps logger 10hz  (Read 369 times)
Offline Offline
Newbie
View Profile
Hi everyone, I have a little proyect for making a gps logger, so far I have set the venus gps at 10hz and I succesfull meke a sketch for log the information to a sd shiel. However it has a little problem, sometimes it logs the information with strange characters.
Here es the sketch.
Code:
#include <SD.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include "I2Cdev.h"
#include "MPU6050.h"
SoftwareSerial gpsSerial(6, 5); // RX, TX (TX not used)
const int sentenceSize = 312;
MPU6050 accelgyro;
int16_t ax, ay, az;
int16_t gx, gy, gz;
char sentence[sentenceSize];
#define LOG_INTERVAL 100
const int chipSelect = 10;
File logfile;
long idd = 0;
long ids = 0;
long idm = 0;
long idh = 0;
void error(char *str)
  Serial.print("error: ");
  Serial.println(str);
  while(1);
  Wire.begin();
  Serial.begin(38400);
  gpsSerial.begin(38400);
  Serial.println("Iniciando MPU");
  accelgyro.initialize();
  Serial.println("Iniciando SD");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Fallo de SD");
    return;
  Serial.println("Inicio Correcto");
  Serial.println("Testeando MPU");
  Serial.println(accelgyro.testConnection() ? "Conexion MPU6050 exitosa" : "Error de Conexion a MPU");
  // create a new file
  char filename[] = "LOGGER00.CSV";
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = i/10 + '0';
    filename[7] = i%10 + '0';
    if (! SD.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile = SD.open(filename, FILE_WRITE);
      break;  // leave the loop!
  if (! logfile) {
    error("couldnt create file");
  Serial.print("Logging to: ");
  Serial.println(filename);
  static int i = 0;
  if (gpsSerial.available())
    char ch = gpsSerial.read();
    if (ch != '\n' && i < sentenceSize)
      sentence[i] = ch;
      i++;
     sentence[i] = '\0';
     i = 0;
     char field[20];
      getField(field, 0);
      accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
  if (strcmp(field, "$GPRMC") == 0)
    Serial.print("Tiempo: ");
    getField(field, 1);
    Serial.print(field);
    logfile.print(field);
    logfile.print("\t");
    Serial.print("Lat: ");
    getField(field, 3);  // number
    Serial.print("Long: ");
    getField(field, 5);  // number
    Serial.print("Velocidad: ");
    getField(field, 7);
    Serial.print("a/g:\t");
    Serial.print(ax); Serial.print("\t");
    logfile.print(ax);
    Serial.print(ay); Serial.print("\t");
    logfile.print(ay);
    Serial.print(az); Serial.print("\t");
    logfile.print(az);
    Serial.print(gx); Serial.print("\t");
    logfile.print(gx);
    Serial.print(gy); Serial.print("\t");
    logfile.print(gy);
    Serial.println(gz);
    logfile.println(gz);
    logfile.flush();
void getField(char* buffer, int index)
  int sentencePos = 0;
  int fieldPos = 0;
  int commaCount = 0;
  while (sentencePos < sentenceSize)
    if (sentence[sentencePos] == ',')
      commaCount ++;
      sentencePos ++;
    if (commaCount == index)
      buffer[fieldPos] = sentence[sentencePos];
      fieldPos ++;
    sentencePos ++;
  buffer[fieldPos] = '\0';
Now changing this value in the line // const int sentenceSize = 312; the sketch woks better or worse according that value, nontheless it always log in some point a line of data with strange characters.
Like this
115948.000   2400.0000   12100.0000   000.0-5948   2372   -15384   -266   70   -1
115948.200   24˜0.0000   12100.0000   000.0-6132   2260   -15532   -235   35   -4
The second line has a weir character there, it happens, according to the value, more or less often.
There is anyone who can help with this glitch?
Logged
UK
Offline Offline
Tesla Member
View Profile
Sounds as if you may be getting bit errors on the software serial connection. You may be able to reduce the frequency of the errors by playing with the serial parameters (you'd need to reconfigure the GPS to match, and I don't know what that would involve) or perhaps it could be affected by the properties of the circuit between the GPS and Arduino.
If you can't eliminate the errors, could you validate the received string to ensure it is syntactically correct before you store it? Evidently the string is only expected to contain decimal digits, a minus sign and whitespace so it should be easy enough to pick out the spurious characters.
Logged
New Jersey
Offline Offline
Edison Member
View Profile
I'd be inclined to reduce the baud rate on the GPS and the frequency with which it updates. Then see if you can get it working. Increasing the baud rate on the serial port may help too.
Logged
Pages: [1]   Go Up
Print
Jump to:
