Topic: How to get 20khz PWM on pin D9 (Read 15250 times) previous topic - next topic
Coding Badly
Channel A output...
Code: [Select]
void analogWriteSAHA( uint16_t value )
 if ( (value >= 0) && (value < 800) )
   OCR1A = value;
Channel B output...
Code: [Select]
void analogWriteSAHB( uint16_t value )
   OCR1B = value;
Thanks Coding Badly for your quick reply! and commented code  8)
Wonderful!
It seems that because the 2 pins are sharing the same timer (PWM T1), it's quite short to implement: excellent! I woudn't have dared to mess with the code: registry frighten me!
I'll have a try now with my Nano ATMega 328
To be compliant with the rest of my code, can I use this (map and constrain) without decreasing the overall performance?
Code: [Select]
void analogWriteSAHA( uint8_t value )
  //  My variable value varies from 0 to 255
  //  but awaited range in OCR1A is from 0 to 799 and nothing else!
    OCR1A = constrain(map(value, 0, 255, 0, 799), 0, 799);
Thks  :)
#17
Apr 29, 2014, 01:37 pm Last Edit: May 01, 2014, 08:14 am by Mat13 Reason: 1
Here is my test: it compiles perfectly, upload ok, but no moves...
The direction leds (green/red) are less bright... than usual.
When a motor is connected, the leds don't light at all...
it must be kryptonite somewhere close...  :smiley-mr-green:
After that, I modified ICR1 to 1599 to get 10kHz (and OCR1A max in the function)
but the behaviour is the same ;-(
... I'll have to buy an oscilloscope  $$
Coding Badly
Quote
This website has been reported as unsafe
Phishing threat:
This site might try to trick you into disclosing your login, password or other sensitive information by disguising itself as another website you may trust.
Instead of hosting images off-site please attach them to your post.  Click Modify to change your post, click Addition Options, click Browse to select the file, then click Save.
Coding Badly
Test with two LEDs (and series resistors) using the Fade example.  If the LEDs get dimmer / brighter then at least you know the pulse width modulation is working.
Yes, good idea!  XD
I didn't succeeded in fading the LED.
With the Analogwrite, it is Ok: LED is fading
With analogWriteSAHA, the LED stays off
Maybe my Arduino Nano V3.0 funduino is not working...
Thanks for any hint!
yours
Mat
Code: [Select]
int led = 9;           // the pin that the LED is attached to
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
void analogWriteSAH_Init( void )
  TCCR1B = (0 << ICNC1) | (0 << ICES1) | (0 << WGM13) | (0 << WGM12) | (0 << CS12) | (0 << CS11) | (0 << CS10);
  TCCR1A =
    (1 << COM1A1) | (0 << COM1A0) |   // COM1A1, COM1A0 = 1, 0
  (1 << COM1B1) | (0 << COM1B0) |
    (1 << WGM11) | (0 << WGM10);      // WGM11, WGM10 = 1, 0
  ICR1 = 799;
  TCNT1 = 0;
  OCR1A = 0;
  OCR1B = 0;
  TIMSK1 = (0 << ICIE1) | (0 << OCIE1B) | (0 << OCIE1A) | (0 << TOIE1);
  DDRB |= (1 << DDB1);
  DDRB |= (1 << DDB2);
  TCCR1B =
    (1 << WGM13) | (1 << WGM12) |              // WGM13, WGM12 = 1, 1
  (0 << CS12) | (0 << CS11) | (1 << CS10);
    OCR1A = value;
// the setup routine runs once when you press reset:
void setup()  {
  analogWriteSAH_Init;
  // declare pin 9 to be an output:
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
void loop()  {
  // set the brightness of pin 9:
analogWriteSAHA(brightness);
// analogWrite(led, brightness);
  // change the brightness for next time through the loop:
  brightness = brightness + fadeAmount;
  // reverse the direction of the fading at the ends of the fade:
  if (brightness == 0 || brightness == 795) {
    fadeAmount = -fadeAmount ;
  // wait for 30 milliseconds to see the dimming effect
  delay(30);
Coding Badly
You forgot something...
Code: [Select]
void setup()  {
  analogWriteSAH_Init();
Thanks but unfortunatly, it was already in the code... there must be something else somewhere else :~
maybe in the wiring.c or .h files? or a previous tweak i may have done in serial file...
I'll do a reinstall!
and meanwhile I'll ask a friend to do the same ;-)
Code: [Select]
void setup()  {
Coding Badly
Reread my previous post.  More carefully this time.  I promise you forgot something.  Just not what you think.
Oh myGod! I forgot the brackets!
Thanks for having spotted that Coding Badly! 8)
Ultrasonic fading led is now working!
Tomorrow a video with the Hbridge hopefully!!
#26
May 03, 2014, 12:21 pm Last Edit: Mar 14, 2018, 08:29 am by Mat13
Hello!
Thansk to Coding Badly's help,
here is the video demonstrating that the ultrasonic PWM eliminates the buzzing sound of the driven DCmotor!  :P
youtube video here : http://youtu.be/FzhUga64fJs
The codes I used are the following:
non ultrasonic code:
Code: [Select]
//  DECLARATIONS
/*  VNH2SP30 pin definitions*/
// to have the wiring compliant with 20kHz pinout, you CANNOT stack the motomonster anymore!
/*  Arduino /..Motomonster1
 ......GND <-> GND pin
 ........5V <-> 5V
 .....pin 7 <-> pin 4 inA motor1
 .....pin 8 <-> pin 8 inB motor1
 .....pin 9 <-> pin 5 pwm motor1
int inApin = 7;  // INA: Clockwise input
int inBpin = 8; // INB: Counter-clockwise input
int pwmpin = 9; // PWM input
#define potR A5
{ // initialization of Arduino's pins
  pinMode(inApin, OUTPUT);
  pinMode(inBpin, OUTPUT);
  pinMode(pwmpin, OUTPUT);
  digitalWrite(inApin, HIGH);
  digitalWrite(inBpin, LOW);
///////////////////////////////// Main Loop ////////////////////////////////////
  int sensor;
  sensor = analogRead(potR);  // range 0-1024
  analogWrite(pwmpin, (sensor/4));
and then ultrasonic code:
Code: [Select]
//  DECLARATIONS
 // with 20kHz PWM pinout is changed, you CANNOT stack the motomonster anymore!
 ........5V <-> 5V
#define potR A5
// INITIALIZATION
  // Stop the timer while we muck with it
  // Set the timer to mode 14...
  // Mode  WGM13  WGM12  WGM11  WGM10  Timer/Counter Mode of Operation  TOP   Update of OCR1x at TOV1  Flag Set on
  //              CTC1   PWM11  PWM10
  // 14    1      1      1      0      Fast PWM                         ICR1  BOTTOM                   TOP
  // Set output on Channel A and B to...
  // COM1z1  COM1z0  Description
  // 1       0       Clear OC1A/OC1B on Compare Match (Set output to low level).
  TCCR1A =
    // Set TOP to...
  // fclk_I/O = 16000000
  // N        = 1
  // TOP      = 799
  // fOCnxPWM = fclk_I/O / (N * (1 + TOP))
  // fOCnxPWM = 16000000 / (1 * (1 + 799))
  // fOCnxPWM = 16000000 / 800
  // fOCnxPWM = 20000
    ICR1 = 799;
  // Ensure the first slope is complete
  TCNT1 = 0;
  // Ensure Channel A and B start at zero / off
  OCR1A = 0;
  OCR1B = 0;
  // We don't need no stinkin interrupts
  // Ensure the Channel A and B pins are configured for output
  // Start the timer...
  // CS12  CS11  CS10  Description
  // 0     0     1     clkI/O/1 (No prescaling)
  TCCR1B =
void analogWriteD9( uint16_t value )
  //  My variable value varies from 0 to 1024
  OCR1A = constrain(map(value, 0, 1024, 0, 799), 0, 799);
  int sensor;
  analogWriteD9(sensor);
For the record, that is actually a good way to ensure PWM is working correctly for a new core (a piezoelectric buzzer is a less expensive tool than a motor+driver).  Just listen for the distinctive frequency and all is good.
Coding Badly
You are welcome.  Thank you for the video.  It illustrates the problem beautifully.
Spritey12
Hello,
I'm just curious if it is possible to add interrupts to code u posted above? I use arduino Uno with atmega328 and i need to interrupt when PWM level changes from High to Low (i need to have some dead zone, around 50-100us, to power up the bootstrap circuit) and the same when opposite? I already tried to put there some interrupts but it seems to not working well for me.
I'd appreciate any help from ur side.
MarkT
For deadtime, just constrain the value passed to the PWM register so there's enough
time with the output low, perhaps 750 rather than 800
Code: [Select]
  OCR1A = constrain(map(value, 0, 1024, 0, 750), 0, 750);
