Topic: SSD1289 : question about the RD pin (Read 14766 times) previous topic - next topic
guix
Ok I understand your misinterpretation ;)
Here is the whole thing, a mess :)
If someone want the .pdn project (for Paint.NET), just ask.
pYro_65
I've just taken some time and removed the resistor attached to RD/3.3v.
I've also soldered a wire onto the pad on the 'RD' side. For now it goes to a 10k resistor, then to 5v.
I have yet to implement the read code, however the hardware changes have not affected the display's operation.
Hopefully I'll have some screen shots in the next couple of days.
Forum Mod anyone?
https://arduino.land/Moduino/
guix
I suggest you use the read code that can be found in the ArduCam library.
Waiting your screenshots :)
pYro_65
#18
Dec 31, 2012, 12:53 pm Last Edit: Mar 07, 2013, 07:39 am by pYro_65 Reason: 1
Finally, got some action. Not perfect yet, there is a slight timing error which I'll weed out soon over some coffee. But here is some preliminary shots.
Thanks guix, your thread helped me to do it.
Forum Mod anyone?
guix
Hello pYro 65,
Good job! Once you fix the errors, can you describe precisely how you did the whole thing?
pYro_65
#20
Jan 01, 2013, 02:31 pm Last Edit: Jan 01, 2013, 02:33 pm by pYro_65 Reason: 1
Sure, i'm going to do a post with a new library one day, for now here is a thread with a video of it running. Once I work out the read function fully I'll post all the details here too.
EDIT: the link may help: http://arduino.cc/forum/index.php/topic,140111.0.html
Forum Mod anyone?
