Topic: Converting a String to Long (Read 9081 times) previous topic - next topic
liveitnerd
I'm writing a web interface to control some WS2801 LED's and am wanting to convert string to long.  The code I have takes a string in the format "0xFFDD00" and needs to be put in to the following line:-
ledStripStatus[0] = 0xFFDD00;
How can I get this converted to be done?
Thanks,
LiveItNerd
Coding Badly
Pick your poison...
[font=Courier New]strtol
strtoul
atol
[/font]
liveitnerd
Sweet.  Thanks!  I tried all of them but I get this instead.
error: cannot convert 'String' to 'const char*' for argument '1' to 'long unsigned int strtoul(const char*, char**, int)'
Coding Badly
[font=Courier New]mystring.toInt()[/font]
liveitnerd
When I try to use toInt() it returns 0.
colourString = "0xFF0000";
ledStripStatus[0]=colourString.toInt();
... where colourString is a String and ledStripStatus Long Array.  Sorry for not understanding this too well.  I'm quite new to Processing and I'm still learning the syntax for it all.
Thanks,
LiveItNerd
PaulS
You need to quit using Strings. While you are figuring out to do that, the toCharArray() method will extract the contents of the String as a char array that can be passed to strtol(), etc.
Coding Badly
Huh.  So it would.  I wonder why the Arduino folks used atol instead of strtol.
In any case, PaulS' suggestion will work.
zoomkat
An example would be good.  :)
Coding Badly
The simplest possible usage of strtol...
void setup( void )
  Serial.begin( 115200 );
void loop( void )
  char buffer[20];
  long value;
  strncpy( buffer, "0xFFDD00", sizeof(buffer) );
  buffer[sizeof(buffer)-1] = 0;
  value = strtol( buffer, NULL, 0 );
  Serial.println( value );
  delay( 1000 );
Coding Badly
Ensure the string parses to an integer...
void setup( void )
void loop( void )
  char buffer[20];
  char* endptr;
  long value;
  strncpy( buffer, "badnews", sizeof(buffer) );
  value = strtol( buffer, &endptr, 0 );
  if ( endptr != &buffer[0] )
    Serial.println( F( "Bad news." ) );
  delay( 1000 );
Coding Badly
Extract a list of integers from a string...
void setup( void )
  Serial.println( F( "----------" ) );
void loop( void )
  char buffer[20];
  char* headptr;
  char* endptr;
  long value;
  strncpy( buffer, "1 2 3 4 5", sizeof(buffer) );
  headptr = &buffer[0];
  value = strtol( headptr, &endptr, 0 );
  while ( endptr != headptr )
    headptr = endptr;
  delay( 1000 );
