Author Topic: Converting a String to Long  (Read 438 times)
I'm writing a web interface to control some WS2801 LED's and am wanting to convert string to long.  The code I have takes a string in the format "0xFFDD00" and needs to be put in to the following line:-
ledStripStatus[0] = 0xFFDD00;
How can I get this converted to be done?
Thanks,
LiveItNerd
Dallas
Shannon Member
Pick your poison...
strtol
strtoul
atol
Sweet.  Thanks!  I tried all of them but I get this instead.
error: cannot convert 'String' to 'const char*' for argument '1' to 'long unsigned int strtoul(const char*, char**, int)'
Dallas
Shannon Member
mystring.toInt()
When I try to use toInt() it returns 0.
colourString = "0xFF0000";
ledStripStatus[0]=colourString.toInt();
... where colourString is a String and ledStripStatus Long Array.  Sorry for not understanding this too well.  I'm quite new to Processing and I'm still learning the syntax for it all.
Thanks,
LiveItNerd
Seattle, WA USA
Seattle, WA USA
You need to quit using Strings. While you are figuring out to do that, the toCharArray() method will extract the contents of the String as a char array that can be passed to strtol(), etc.
Dallas
Shannon Member
Huh.  So it would.  I wonder why the Arduino folks used atol instead of strtol.
In any case, PaulS' suggestion will work.
An example would be good.  smiley
put in key search words,
Dallas
Shannon Member
The simplest possible usage of strtol...
void setup( void )
  Serial.begin( 115200 );
void loop( void )
  char buffer[20];
  long value;
  strncpy( buffer, "0xFFDD00", sizeof(buffer) );
  buffer[sizeof(buffer)-1] = 0;
  value = strtol( buffer, NULL, 0 );
  Serial.println( value );
  delay( 1000 );
Dallas
Shannon Member
Ensure the string parses to an integer...
void setup( void )
void loop( void )
  char buffer[20];
  char* endptr;
  long value;
  strncpy( buffer, "badnews", sizeof(buffer) );
  value = strtol( buffer, &endptr, 0 );
  if ( endptr != &buffer[0] )
    Serial.println( F( "Bad news." ) );
  delay( 1000 );
Dallas
Shannon Member
Extract a list of integers from a string...
void setup( void )
  Serial.println( F( "----------" ) );
void loop( void )
  char buffer[20];
  char* headptr;
  char* endptr;
  long value;
  strncpy( buffer, "1 2 3 4 5", sizeof(buffer) );
  headptr = &buffer[0];
  value = strtol( headptr, &endptr, 0 );
  while ( endptr != headptr )
    headptr = endptr;
  delay( 1000 );
