Topic: Help with combining 2 sketches together. (Read 3283 times) previous topic - next topic
ArmenFrost
Just tried that. Compiles fine but still nothing. Absolutely no reaction from Arduino when  buttons are pressed or R is sent to it.
Grumpy_Mike
I didn't say it would fix it, I am looking for errors you made.
Have you made the same error anywhere else?
AWOL
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
Grumpy_Mike
Quote
So put some debug printing in and see what you get. Post the code with the debug printing in it and say what happens.
ArmenFrost
Let me just start off by saying thank you guys for taking the time to help me. I tried the debugging code, but when I enter it anywhere in the loop sections then everything stops working again. SO nothing really prints for me to tell you where its stopping. So what i did was slowly take out code until it started working again. What I found out is that it all orks fine if I only run one code in the loop section at a time. But if I want to combine them then I can only go so far as this point
Code: [Select]
  if (Serial.available() > 0)
         incomingByte = Serial.read();
         if (incomingByte == 'R')
         //if I add anything in here then the whole thing stops working
Ive tried adding a simple LED turn on pin13 Ive tried to just print a simple word to serial. Nothing Just kills the whole thing.
Here is the complete code again.
Code: [Select]
#include <SdFat.h>
#include <Keypad.h>
const int chipSelect = 8;
SdFat sd;
int incomingByte;
SdFile myFile;
const byte ROWS = 4; // Four rows
const byte COLS = 3; // Three columns
// Define the Keymap
char keys[ROWS][COLS] =
    '1','2','3'    }
    '4','5','6'    }
    '7','8','9'    }
    '*','0','#'    }
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = {
  5, 4, 3, 2 };
// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = {
  9, 7, 6 };
// Create the Keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char code[1024];
int index;
#define ledpin 13
  if (!sd.init(SPI_HALF_SPEED, chipSelect)) sd.initErrorHalt();
void writeToFile()
  // open the file for write at end like the Native SD library
  if (!myFile.open("codes.txt", O_RDWR | O_CREAT | O_AT_END)) {
    sd.errorHalt("opening codes.txt for write failed");
  code[index] = '\0';
  myFile.println(code);
  // close the file:
  myFile.close();
  Serial.println("done.");
void printDigits(byte digits){
  char key = kpd.getKey();
  if(key)  // Check for a valid key.
    Serial.println(key);
    switch (key)
    case '#':
      writeToFile();
      index = 0;
      Serial.print(code);
    default:
      code[index] = key;
      index++;
           Serial.println("RESET");   //this code will kill the hole sketch. If i erase it everything works fine.
SInce it all stops working and I cant see what happens when I write a code after the
Code: [Select]
I cant really know if that statement is working. Ive tried to add debug code but like I said if I add any serial.print anywhere in the loop section then nothing happens.
PaulS
You are using an SD card reader/writer. That is an SPI device. That means that it uses pins 11, 12, and 13. That means you can NOT use the onboard LED for ANYTHING. Or pin 13.
ArmenFrost
Ok I get the led on pin 13. I have even tried pin 10. But lets just forget about the pins, why wont it print to serial?
Arrch
Let's not. Start by fixing the issues you already have, then if the issue persists, post the updated code. It's possible that the pin conflict could be causing a hold up in another part of the code.
PaulS
Code: [Select]
Do you know that you get past this?
ArmenFrost
I don't have a problem with pin 13. Im not trying to run anything on pin 13. I was just using that to try and see if it will work. I even tried on pin number 10. Which is not connected to anything. So we can forget about those pins. Even if dont try to send a signal out to any of the pins after the if statement and only try to print something to serial it wont print either. So my issue is not connection with the pins.
And paul the answer to your questions is yes I think so. Because if I dont add to the loop of the first sketch, which the line you asked about is in, then it all works great. So I think it passes that point with no issues.
AWOL
Anyone what?
We seem to be short on output and observations.
Grumpy_Mike
Quote
If tharpt is truly happening then it is not getting out of setup so see where this hangs.
ArmenFrost
If I just leave this in the loop section
Code: [Select]
    switch (key)
    case '#':
      writeToFile();
      index = 0;
      Serial.print(code);
    default:
      code[index] = key;
      index++;
Then it works. It saves the digits.
But as soon as I add anything between the curly brackets after
Code: [Select]
         if (incomingByte == 'R'){
Then nothing works. So I think it gets passed the setup. But hey I dont know I could be wrong.
Grumpy_Mike
Quote
But there is no call to the write file so how can it save the digits?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
