Author Topic: ATTINY Beacon  (Read 365 times)
I love YaBB 1G - SP1!
Hia, I've found this old thread where someone under the nick Anymouse mentions having used the attiny as a morse code beacon in the AM band:
http://arduino.cc/forum/index.php/topic,8456.msg68177.html#msg68177
I will very much appreciate to know how complex is to "port" the code in that thread (below) to be used on ATTINY's? I don't think is as simple as changing pin numbers unfortunately.
/a
// ### INC ### Increment Register (reg = reg + 1)
#define ASM_INC(reg) asm volatile ("inc %0" : "=r" (reg) : "0" (reg))
  DDRB=0xFF;  //Port B all outputs
  //Do one dit to determine approximate frequency
  millisAtStart=millis();
  dit();
  millisAtEnd=millis();
  Serial.print(millisAtEnd-millisAtStart);
  Serial.print(" ");
  Serial.print((length_dit+pause_dit)*period_broadcast*256/(millisAtEnd-millisAtStart)/2);
  Serial.print("kHz ");
  Serial.println();
  dah();
  dit();
  dah();
  dah();
  pause();
  dah();
  dit();
  dah();
  dah();
  pause();
  dah();
  dah();
  dit();
  dit();
  pause();
  pause();
void dit(void)
  for(int i=0;i<length_dit;i++)
    broadcast(period_broadcast);
  for(int i=0;i<pause_dit;i++)
    dontbroadcast(period_broadcast);
void dah(void)
  for(int i=0;i<length_dah;i++)
  for(int i=0;i<pause_dah;i++)
void pause(void)
  for(int i=0;i<length_pause;i++)
void broadcast(int N_cycles)
  unsigned int portvalue;
  for (int i=0;i<N_cycles;i++)
    portvalue=0;
    do
      PORTB=portvalue;
      ASM_INC(portvalue);
    while(portvalue<255);
void dontbroadcast(int N_cycles)
  PORTB=0x00;
    portvalue=0;
    do
      ASM_INC(portvalue);
      //add some assembly No OPerations to keep timing the same
      asm volatile ("NOP");
« Last Edit: December 06, 2012, 11:37:47 am by armadillo » Logged
Denmark
I justed tryed the sketch on a Attiny85.
It is now sitting on my desk, and morsing with a Led on pin PB3.
ola erni,
and if you put a wire on the other out pins and tune a radio to 1337 AM do you hear the code also?
that's the part i'm more interested on knowing how to work out.
tx!
/a
Denmark
My Atiiny is running at 8mHz so I would expect an output Freq. of  668kHz, and that is what is shown in the serial monitor:
196 668kHz
You will have to figure out what pin is the outputpin on the Attiny, I haven't studied the sketch in deep, actually I don't understand the ASM part of it.
Many thanks for checking that out, I hope to receive my ATTINY next week and try it out. Hopefully someone else can chime in and give us a hint on the asm part.
Dallas
Online Online
Shannon Member
...the variable portvalue is assigned to a pair of registers.
      PORTB=portvalue;
...the least significant eight bits of portvalue are written to the I/O register for PORTB.
      ASM_INC(portvalue);
...which becomes...
asm volatile ("inc %0" : "=r" (portvalue) : "0" (portvalue))
...which becomes something like...
asm volatile ("inc r24")
...which just increments the value in the register used to store the least significant eight bits of portvalue.
The whole thing is a silly replacement for this (no assembly required)...
void broadcast( int N_cycles )
  uint8_t portvalue;
  for ( int i=0; i < N_cycles; i++ )
    portvalue = 0;
    do
      PORTB = portvalue;
      ++portvalue;
    while( portvalue < 255 );
« Last Edit: December 06, 2012, 06:33:08 pm by Coding Badly » Logged
Coding Badly, that's very generous from your part.
I'm looking fwd to test it, will report back.
