Topic: Using a temperature sensor I2C. Where do registers come into code? (Read 4281 times) previous topic - next topic
Richard_N
Hi
I'm working programming a Leonardo board and I have a MCP9801 attached to a shield I have been given for this project.
#include <Wire.h>
int I2C_address = 0b1001000 // define address of bus
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
   Wire.beginTransmission(I2C_address); // transmit to I2C
    Wire.write(0b00000000);              // sends one byte
  Wire.endTransmission();    // stop transmitting
  Wire.requestFrom(I2C_address, 2);    // request 2 bytes from address.
  while(Wire.available())    // slave may send less than requested
    int temp1 = Wire.read(); // receive a byte as character
    int temp2 = Wire.read(); // receive a byte as character
    Serial.println(temp);         // print the character
1) I know what register the ambient temperature is on on the sensor  but where in this code do I need to use this information
2) My lecturer talked about taking two bytes from the sensor and bit shifting to get 9 bit from the sensor, Why would I do that? and indeed what's the best way?
3) Finally there's some simple maths to perform on the output to convert it from Raw data to a temperature as defined in the data sheet for the temp sensor, What would be the best way to do this?
Thank you for your help, I hope this is clear
R3dEyedFox
First step, get the data sheet for the hardware, it'll list the location of each register.
majenko
That all depends on what you want to do with the data.
You'd do that because the sensor provides 9 bits of data, and I²C is an 8 bit protocol.  The best way would be to use bit shifting - as you have already said.
By reading the formula from the data sheet and typing it into the program, using relevant variables.
Richard_N
I have the data sheet I know the register pointer I need, I'm just not clear on where this goes into the code. I want to read from the register for ambient temperature and the end result at this stage only needs to be printing the temp in degrees celsisu on the serial monitor.
My second question may not have been clear enough:
Do you have any guidance on using bit shift, is the bit in the examples in the IDE entitled strings relevant?
Should my order be something like this:
I2C transmits two bytes
then I do the bitshifting ( I want the first byte and the first bit of the second byte?)
the the maths to get it from raw data into celsius
then I print?
R3dEyedFox
put the regs here
    int temp1 = Wire.read(0x00); // receive a byte as character
    int temp2 = Wire.read(0x00); // receive a byte as character
Grumpy_Mike
http://arduino.cc/en/Reference/Bitshift
No.
R3dEyedFox
The other dude pretty much explained bitshifting, here is the ref page
the temp is received in raw data, you need to convert the raw value into Celsius
writing some variables that hold the temperature value might be helpful
Richard_N
Ok then two more things to clarify from your repsonses, but I think it's becoming clear.
Where you've put 0x00 I'll put 0000000 (the register pointer for ambient temp register?)
I want all of the first byte and to "add" the first bit of the second byte on the end?
What's the function called to join the two pieces of data after I've done the bit shifting?
Grumpy_Mike
Yes.
Yes.
The full name is the inclusive OR function the operation symbol is a single | ( that is not an i or an l )
Richard_N
Thanks very much I'll post back with my finished code later on.
I appreciate your patience with a useless mechanical engineer currently getting lost in the world of programming
Richard_N
My completed code if it's of interest / use to other people looking at this topic for help.
// This code reads a temperature sensor using an I2C bus. Presents data in serial monitor.
// Uses wire library
// Uses arduino, I2C bus and temperature sensor
// RICHARD NASH 13/12/12
#include <Wire.h>
int I2C_address = 0b1001000; // define I2C Address
    Wire.write(0b00000000);              // sends one byte.
  Wire.requestFrom(I2C_address, 2);    // request 2 bytes from address. Because sensor produces 9 bit
    int temp1 = Wire.read(); // receive a byte as integer
    int temp2 = Wire.read(); // receive a byte as integer Can change resolution of by chaning 2nd and 3rd bit of the register pointers.
    int a = temp1 <<1; // bitshift 1 to the left to allow for 9bit data from temp sensor
    int b = temp2 >>7; //bitshift 7 to the right to allow for 9 bit data from temp sensor.
    int tempRaw = a|b;  // define int rawtemp as the combination of integer a and b. We now have 9 bits of data.
    int tempC = tempRaw * 0.5 ;// 0.5 = 2^-1 since T = C x 2^n where c is the binary code value, and n is dependent on resolution used. tempC is temperature in celsius
    Serial.println(tempC);         // print the character
cjdelphi
Waymon - Look at your breadboard, see the 2 ceramic caps and your crystal, GND is not connected!
only 1 side of the crystal is connected to GND via the caps, the other is not..  - fix that and it should upload fine.
