Loading...
Pages: [1]   Go Down
Author Topic: IR sensor circuit problem  (Read 865 times)
Offline Offline
Newbie
View Profile
I would like to do a IR reflective sensor so I constructed this circuit......Why does the circuit no function at all???
What's wrong of this circuit???
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Lots of possible reasons:-
1) Because you have not wired it up correctly.
2) Because you have the IR source too far away, try it at a distance of less than 10mm
3) Because you are not blocking it with something opaque to IR.
4) You have not specified what sensor that it, you have just drawn it as a transistor.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Also maybe the IR diode and the photo-transistor aren't designed to use the same wavelength frequency?
Lefty
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
Are D and Q in one package?
Logged
Kitchen-Sink Arduino-compatible boards
Offline Offline
Newbie
View Profile
http://www.cytron.com.my/viewProduct.php?pcode=SN-IRS-02&name=IR%20Sensor%20Set%20With%20Socket
the sensor is one set......and I am sure no problem with my circuit
Logged
Online Online
Brattain Member
View Profile
WWW
Just given the circuit diagram then nether do we.
What you need to do is to post a photograph of how you have wired it up along with the code you are running.
Logged
Offline Offline
Edison Member
View Profile
WWW
If it's not working, it's about 90% probability you have the thing wired wrong. The other
10% is they sold you a bad part.
Also, note, as G_M indicated in his first post, those small packages sense properly over only
a very short range, a couple of mm. The data sheet will say.
Now, the larger devices will sense over a much longer range, but the following one probably
has pickup to the side directly from the Led. Usually there is a light baffle in between Led
and pickup device.
http://www.cytron.com.my/viewProduct.php?pcode=SN-IRS-01
Logged
Offline Offline
Newbie
View Profile
This is my pcb design.......
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
You've shown the receiver as being a diode, but the spec sheet says it's a transistor! Is the Collector connected to +5V?
Does the output stay at zero (I'm rather expecting it does) so increase R2 to something like 1M
If it stays at or near 5V, then either it is surprisingly responsive and picking up stray IR, or you've damaged it.
What are you using as a reflector?
« Last Edit: December 15, 2012, 06:34:13 pm by Folderol » Logged
Online Online
Brattain Member
View Profile
WWW
No it is not, it is a schematic. It is a different schematic than you said you were using in the first post.
I asked:-
Quote
If you are going to keep changing your story and refusing to cooperate with requests you won't win many friends here.
Logged
Pages: [1]   Go Up
Print
Jump to:
