Topic: 13 3VDC 58mA motors driven via code (Read 593 times) previous topic - next topic
dvanness
Need to drive 13 3vdc motors separately from the arduino.  Suggestion? What wiring setup is needed?
I image a Transitor and a Diode is going to come into play
HazardsMind
Do these motors need to go forward and reverse?
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
AWOL
Also do you need to individually control their speed?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
retrolefty
Quote
Yep, one of each for each motor at least. And more stuff in you want other then just on/off control for the motors, like forward/off/reverse or bidirectional plus variable speed. Also you need to know the max current draw a each motor so you can see if you can power it from the arduino board (not likely probably) or you will need an external DC power source capable of supplying the total current demand of all the motors being on at the same time.
Lefty
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
