Loading...
Pages: [1]   Go Down
Author Topic: Determining which AVRS support external RAM  (Read 450 times)
UK
Offline Offline
Sr. Member
View Profile
Evening all,
A quick pointer in the right direction please; what should I look for in an AVR's datasheet that would tell me whether or not the device supports external RAM?
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
I think it's only the ATmega128 which can have external RAM.
Here's the datasheet: http://www.atmel.com/Images/doc2467.pdf
On page one it says "Up to 64Kbytes Optional External Memory Space", that's what to look for.
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Atmega1280/2560 as well.
Also search for "External Memory Interface" although it should be on page 1 as fungus says.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Tasmania - Australia
Offline Offline
Sr. Member
View Profile
WWW
An example for you to look at http://ruggedcircuits.com/html/quadram.html
These folks build rugged Arduino boards.
Paul
Logged
Renewable Energy Monitor Project http://paulalting.com/hydrosolar.php     No, I don't really suffer from insanity, I enjoy it.     I do it with Eclipse IDE and Jantje's AVR plugin http://baeyens.it/eclipse/
Offline Offline
Tesla Member
View Profile
WWW
Unfortunately although the SAM3 has an external memory interface the Due designers chose not to bring out one of the address lines and so IMO stuffed up royally.
_____
Rob
Logged
Left Coast, CA (USA)
Online Online
Brattain Member
Measurement changes behavior
View Profile
_____
Rob
Well they were in hurry to meet a deadline for release.  smiley-grin
Lefty
Logged
Offline Offline
Tesla Member
View Profile
WWW
smiley
One pin and they screwed external memory use. Go figure.
Maybe I should re do this
http://arduino.cc/forum/index.php/topic,129198.msg1020544.html#msg1020544
______
Rob
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
Quote
external RAM?
Why?  By the time you add external RAM to an Arduino, you're looking at a system cost comparable to one of the microprocessor-based boards (Beaglebone, Raspberry Pi, Xmega-A1 Xplained) that already includes RAM (typically, quite substantial amounts of RAM.  The XPlained, with 8MByte is the smallest.)
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
It's easy to add SPI-bus addressable RAM to an Arduino for extra storage but if that's not suitable then you probably need to go to an ARM based board.
Logged
UK
Offline Offline
Sr. Member
View Profile
Code:
I'm not adding it to an Arduino per se - but rather I've been working on my own board as part of a project for the last 3 months using an ATMega1284, but it's got to the point where I've run out of I/O (I have port expanders yes, but I can't see me activating another SPI chips' SS pin using the port expander) I'd also like more interrupts, not pin change interrupts. Changing to a larger AVR seems like a much more realistic option than throwing away the last three months and starting again. I'd also like to retain the ability to use the Arduino IDE for a while...
8 bit AVR is my first experience with micros, so I don't fancy jumping on the bandwagon of microprocessors just yet - i'll stick with controllers. Plus, I don't see the educational benefit of buying ready made hardware...
As for cost, an external RAM chip only costs a couple of £s or $s, depending which side of the ocean you're on! smiley-grin
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Why not?
Logged
UK
Offline Offline
Sr. Member
View Profile
I'm already using an SPI port expander, so I'll then be accessing two SPI devices at once?
Logged
Valencia, Spain
Offline Offline
Edison Member
View Profile
Oh, the "port expander" is an SPI device. That would make it awkward, yes.
Still, there has to be a way to juggle it around and make it work. Can you add an extra 74HC595 or something...?
Logged
UK
Offline Offline
Sr. Member
View Profile
Yep, could be a pain :-D
I'll take a look re your suggestion - but I may just stick with my current solution and look at a 32 bit chip in a later version that'll inherently have more RAM, plus CAN capability etc.
Logged
Pages: [1]   Go Up
Print
Jump to:
