Loading...
Pages: [1]   Go Down
Author Topic: Need help in Coding a SSI Binary Absolute rotary encoder  (Read 208 times)
Offline Offline
Newbie
View Profile
Hi
I am new to using a Ardunio programming.
I have written the following code after reviewing several codes online but still not getting any readings
Code:
/* Vikash Balasubramanian
SSI (Serial Synchron Interface)
Hardware specifications:
* 13-bit rotary absolute multiturn encoder
* Interface: SSI (with RS485 line definitions)
* encoded as: Binary
* SSI:
  - SSI-Clock TicTac must be equal or less 10µs.
  - 14 Clock TicTac are needed for the whole Position consiting of a 13 Bit word, the first TicTac is needed for the status bit, which enconde the status of the device, (0) for not clear.
  - After the the 14 TicTacs a puse of max. 80µs is needed for a new Position to be available.
* This Program:
  - emulates a SSI with the Arduino Ports 12 (clock) and 11 (data).
  - transform the binary code into absolute angle values
  - send the Position to COmputer via USB
Pins Chosen for Arduino UNO
#define SSI_CLOCK 12
#define SSI_DATA 11
#define ENCODER_LENGTH 13
#define ENCODER_SPEED 4
byte encoder[ENCODER_LENGTH + 1];
byte encoderRev[ENCODER_LENGTH];
unsigned long value;
float angle;
int bitRes;
byte dummy;
functionprototypes
void getPosition();               // saves the status bit and the 13 position bits in the encoder, read from the register as PINB. The only time-critical process.
void condensePosition();          // condenses the recieved Byte (PINB) in encoder  to the only intersting bit (PB3) in PINB.
void transformPosition();         // transforms the 13 bit binaryArray into absolute angle
void sendPosition();              // sends the absolute angle - enclosed in '255'
void setup (){
  pinMode(SSI_CLOCK, OUTPUT);       //
  pinMode(SSI_DATA, INPUT);         //
  PORTB = B1111111;
  if (PINB & (1<<PORTB3)) // this means that if PB3 is low it will read 0 and if PB3 is high it will read a value different from 0, in this case the value will be 0×08, or in binary 0b00001000.
    getPosition();
    Serial.println ("PortB3 not high");
  if(Serial.available())
    Serial.println("Serial Available");
    while(Serial.available()>0)
      dummy = Serial.read();
    condensePosition();
    sendPosition();
  delay(2);
void getPosition()
  for(bitRes = 0;bitRes <= ENCODER_LENGTH; bitRes++)          // Untested yet
     encoder[bitRes] = 0;
     encoderRev[bitRes]=0;
  delayMicroseconds(40);
    PORTB = (0<<PORTB4);
    delayMicroseconds(ENCODER_SPEED);
    PORTB = (1<<PORTB4);
    encoder[bitRes]= PINB;  //delayMicroseconds(3) fits a 10us tictac
  delayMicroseconds(100);
    for(bitRes = 0; bitRes < ENCODER_LENGTH; bitRes++)
      if(encoder[bitRes] & (1<<PORTB3))
        encoder[bitRes] = 1;
   value =0;
     encoderRev[ENCODER_LENGTH-1-bitRes] = encoder[bitRes];             // convert to unsigned long int
   for (bitRes = 0; bitRes <ENCODER_LENGTH; bitRes ++)
      value = value + pow(2,bitRes)*encoderRev[bitRes];             // convert to unsigned long int
   Serial.print ("Value = ");
   Serial.println (value);
void sendPosition()
  angle = (value/(pow(2,ENCODER_LENGTH))) * 360 ;
  Serial.print("Angle =");
  Serial.println(angle);
Can some one tell me where am I going wrong.
Thanks
Logged
Pages: [1]   Go Up
Print
Jump to:
