Loading...
Pages: [1]   Go Down
Author Topic: WiFi Shield - WiFi.begin returns "4"???  (Read 186 times)
Offline Offline
Newbie
View Profile
When I'm doing
status = WiFi.begin([ssid],[pass]);
Serial.println(status);
Status is neither WL_CONNECTED nor WL_IDLE_STATUS, which are the two possible responses outlined in the official reference
http://arduino.cc/en/Reference/WiFiBegin
Status is the number 4.
and of course, I couldn't connect to wifi
What???
I've pressed the reset button a million times, is there a more powerful factory restore button?
Logged
Offline Offline
Newbie
View Profile
It would help to see all of your code. The number you're getting may be because of the network you're trying to connect to. If you're trying to connect to a WEP network, using "pass" is not going to work, as you have to provide the hex key to gain access. Again, seeing all of your code would be very helpful.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
What values do WL_CONNECTED and WL_IDLE_STATUS correspond to?
Why are ssid and pass in square brackets in that call?
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
.../WiFi/utility/wl-definitions.h:
Code:
typedef enum {
WL_NO_SHIELD = 255,
        WL_IDLE_STATUS = 0,
        WL_NO_SSID_AVAIL,
        WL_SCAN_COMPLETED,
        WL_CONNECTED,
        WL_CONNECT_FAILED,
        WL_CONNECTION_LOST,
        WL_DISCONNECTED
} wl_status_t;
Status 4 is WL_CONNECT_FAILED. See .../WiFi/WiFi.cpp
Code:
int WiFiClass::begin(char* ssid, const char *passphrase)
uint8_t status = WL_IDLE_STATUS;
uint8_t attempts = WL_MAX_ATTEMPT_CONNECTION;
    // set passphrase
    if (WiFiDrv::wifiSetPassphrase(ssid, strlen(ssid), passphrase, strlen(passphrase))!= WL_FAILURE)
     do
     delay(WL_DELAY_START_CONNECTION);
     status = WiFiDrv::getConnectionStatus();
   while ((( status == WL_IDLE_STATUS)||(status == WL_SCAN_COMPLETED))&&(--attempts>0));
    }else{
    status = WL_CONNECT_FAILED;
    return status;
« Last Edit: December 07, 2012, 10:00:06 am by dxw00d » Logged
Pages: [1]   Go Up
Print
Jump to:
