Author Topic: code for display numbers atseven segment display using 4x4 keypad, decoder 7447  (Read 363 times)
hi I am new in arduino too, and i want to display numbers 0 to 9, in a 7-segment display using keypads (4x4) and arduino, please let me know if somebody can help me thank you.
« Last Edit: December 10, 2012, 04:59:53 pm by jc7molina » Logged
UK
What help do you need?
DELHI
SIMPLE CODE THAT MIGHT ANSWER YOUR QUESTION
byte seven_seg_digits[10][7] = { { 1,1,1,1,1,1,0 },  // = 0
                                                           { 0,1,1,0,0,0,0 },  // = 1
                                                           { 1,1,0,1,1,0,1 },  // = 2
                                                           { 1,1,1,1,0,0,1 },  // = 3
                                                           { 0,1,1,0,0,1,1 },  // = 4
                                                           { 1,0,1,1,0,1,1 },  // = 5
                                                           { 1,0,1,1,1,1,1 },  // = 6
                                                           { 1,1,1,0,0,0,0 },  // = 7
                                                           { 1,1,1,1,1,1,1 },  // = 8
                                                           { 1,1,1,0,0,1,1 }   // = 9
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  writeDot(0);  // start with the "dot" off
void writeDot(byte dot) {
  digitalWrite(9, dot);
void sevenSegWrite(byte digit) {
  byte pin = 2;
  for (byte segCount = 0; segCount < 7; ++segCount) {
    digitalWrite(pin, seven_seg_digits[digit][segCount]);
    ++pin;
  for (byte count = 10; count > 0; --count) {
   sevenSegWrite(count - 1);
  delay(4000);
AMPS
hi this works for seven segmen display, buy what i need to do is, when a press number 1 in my keypad 4x4 y need the same number in my seven segment display , if i press 2 i need the number 2 in m in my seven segment display and i need to do the same thing from 0 to 9.
What i have to use is 4x4 keypad, decoder 7447, and seven segment display.
thank you for all your help.
« Last Edit: December 10, 2012, 04:38:25 pm by jc7molina » Logged
I need to do is, when a press number 1 in my keypad 4x4 y need the same number in my seven segment display , if i press 2 i need the number 2 in m in my seven segment display and i need to do the same thing from 0 to 9.
Melbourne, Australia
Shannon Member
Lua rocks!
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
