Topic: How i2c can't be work with UNO and pro mini send lots of Data. (Read 917 times) previous topic - next topic
Phodal
I try to send temperature data form the Arduino pro mini to the Arduino UNO.But lose a lot data but the first .
I think the i2c work like a multi-threading .So,I do this code.But How I could send a data easy???
The temperature it a double number,I couldn't recevie the data formally.
Code: [Select]
#include <Wire.h>
int test[]={};
int i=0;
  Wire.begin(4);                // join i2c bus with address #4
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);           // start serial for output
  delay(400);
  Serial.println("fd");
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int h)
    while(1 < Wire.available()) // loop through all but the last
      char c = Wire.read(); // receive byte as a character
      Serial.print(c);         // print the character
   int  x=Wire.read();
   Serial.println(x);
   delay(100);
Code: [Select]
#include <Wire.h>
  Wire.begin(); // join i2c bus (address optional for master)
byte x = 0;
  double z=15.52;
  int t=(int)z;
  int y;
  y=(z-t)*100;
  byte ts=14;
  Wire.beginTransmission(4); // transmit to device #4
  Wire.write(y);
  Wire.endTransmission();    // stop transmitting
  Wire.write(t);
  Wire.write(ts);
PaulS
You are sending 2 ints and a byte, in three separate transmissions. That will result in three separate calls to the receive event. The first two will have two bytes to read. The second will have one.
In the 2 byte case, you are reading/storing the first and printing it as a char, and then reading/storing the second and printing it as an int. I don't think you are loosing data as much as mangling it.
Though you've offered no proof that there is a problem - no serial output - nor have you explained HOW the two Arduinos are connected, nor any explanation as to why there are two for such a simple task.
Phodal
I think the event will receive the data with be pause.And the loop function with continue to the work.So the result it shows:
Code: [Select]
15
fd
52
fd
14
fd
fd
as so on...
I don't know how I can receive such like the 15.52 and store it.last it change from Arduino example,but just a simple example.
Nick Gammon
Code: [Select]
   int  x=Wire.read();
   Serial.println(x);
   delay(100);
This is an interrupt service routine. Don't call Serial.print inside it. Don't call delay. Then get back to us.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
