Topic: How can I simplify this simple code? (Read 3719 times) previous topic - next topic
ZacharyBruno
I have this relatively simple function that I believe can be simpler, but I'm not entirely sure how. I'm hoping this will give me more insight as to how I can make my other functions simpler as well.
This function turns IMU roll data received (clockwise roll goes to positive 180 degrees/counterclockwise roll goes to -180 degrees) to 360 degrees of roll. Here's the function:
float Plane::to360(String dir)
  if (current(dir) < 0) {
    absRollAngle = (360 + current(dir));
  else {
    absRollAngle = current(dir);
  return absRollAngle;
Thanks in advance,
Zachary
liuzengqiang
Assuming current(dir) returns the numerical angle, you can do this:
absRollAngle=(current(dir)+360)%360;
http://arduino.cc/en/Reference/Modulo
Graynomad
float Plane::to360(String dir) {
  return current(dir) < 0 ?  360 + current(dir) : current(dir);
Mind you this doesn't set absRollAngle, is that a global? And if so why return it?
This may be less lines of source code but I'd say the generated code would be the same.
______
Rob
PaulS
Why are you using Strings? Why are you converting the String to a value 3 times?
A ternary operator (there is only one) wold reduce that to 2 lines of code, at the risk of making the code harder to understand.
AWOL
Strings apart, shouldn't that be:
while (current(dir) < 0) {
or something similar?
liuzengqiang
ZacharyBruno
Since I first started developing this program, I've learned about Strings and how bad they are (Although they make your code so readable).
I really like this method... when I try compiling, though, it says:  invalid operands of types 'float' and 'int' to binary 'operator%'
liuzengqiang
Since you didn't say what current(dir) does, I assumed it returns integer.
absRollAngle=(int(current(dir))+360)%360;
AWOL
I think the modulo is easy enough.
Easy, yes, but insufficient - if the initial value is more negative than -360, it won't work.
e.g. (-540 + 360) % 360 = -180.
ZacharyBruno
AWOL, current(dir) will never be more than 180 or -180.
Ok... too bad modulo doesn't work with float. What about this piece of code? I have a tolerance level. Basically, I want it to return true if the amount of roll is out of the desired roll with a specific tolerance. Is there a better way to write this?
boolean Plane::planeDisplaced(String dir, float input) {
/////// Checking To See if Plane is Within Bounderies ///////
     if (current(dir) < (input - tolerance) || current(dir) > (input + tolerance)) {
       return true;
     else {
       return false;
Thanks in advance,
Zachary
PeterH
You seem to be routinely passing numeric values around as Strings (and presumably parsing them again and again each time you need to access the value). You should really consider using numbers instead of strings. You could slightly simplify your bounds check using abs(), but I don't see it making a huge difference. Get rid of those Strings, though.
westfw
It depends on what you mean by "simpler."
The "modulo" solution makes for a short expression, but will increase execution time, because "modulo" is a relatively expensive calculation.
The "ternary operator" (x ? y:z) makes for fewer lines of code in the source, but it harder to read (IMO), and is likely to produce the same code as the if/else statement.
As other have said, your use of Strings is inappropriate and inefficient.  Assuming that the argument to your function MUST be a string (ie, cleaning up this function, but not looking beyond it), you can improve things by only doing the string to number conversion once:
  float dirval = current(dir);   // (or maybe "int" ?)
  if (dirval < 0) {
    absRollAngle = (360 + dirval);
  }  else {
    absRollAngle = dirval;
ZacharyBruno
Thanks everyone. I have taken your advice and altered my program to use compiler variables (bytes) instead of Strings and chars. I think it will run more efficiently now. Can someone please direct me to an article (Or give me an explanation) on why using String variables are usually bad in C++/Arduino?
Thanks again,
Zachary
liuzengqiang
There is not an article about using String class in Arduino is bad yet but from experience of many members and the fact that Arduino's free() function is buggy, it is easy to conclude that keep using String class will eventually drain memory to zero and crash the program.
wildbill
Read Nick's sticky in this forum - it explains it and has a link to a discussion thread on the topic.
