Loading...
Pages: [1] 2   Go Down
Author Topic: motor shield current monitoring code  (Read 613 times)
Offline Offline
Newbie
View Profile
Can anyone help with the code that will monitor pin A0 and A1 on the Arduino motor shield R3.  I want to stop the motors once the A0 and A1 pins detect a set parameter for overcurrent i.e. motor stall?
Logged
UK
Offline Offline
Tesla Member
View Profile
Which part of it do you need help with?
Logged
Offline Offline
Newbie
View Profile
I can't understand how i get the board to read the current the motor is pulling and then incorporate that in an if statement.  Here's my code efforts to date.  At the moment the value that prints is always 16 regardless of how much load i apply to the motor.
Code:
int Bbrake=8;//brake signal for motor B
int Abrake=9;//brake signal for motor A
int motorspdB=11;//PWM speed signal for motor B
int motorspdA=3;//PWM speed signal for motor A
int motorA=12;
int motorB=13;
//int limit=A0
void setup () {
  // int sensorValue=analogRead(A1);
  pinMode(A1,INPUT);//motor current monitor B
  pinMode(A0,INPUT);//motor current monitor A
  pinMode (13, OUTPUT);//motor B enable and direction HIGH or LOW
  pinMode (12, OUTPUT);//motor A enable and direction HIGH or LOW
  pinMode (8, OUTPUT);//Brake motor B
  pinMode (9, OUTPUT);//Brake motor A
//  int Current = 0; //Value of current
  void loop () {
 int limit =1; //Value that triggers motor to shutoff once it has reached endpoint
  analogWrite  (motorspdB,255);
  digitalWrite (motorB,HIGH);
  digitalWrite (Bbrake,LOW);
  delay(2000);
  Serial.println(sensorValue);
  if (sensorValue<limit)
    digitalWrite (Bbrake,HIGH);
  delay(5000);
 // digitalWrite (Bbrake,LOW);
 // delay(5000);
  digitalWrite (motorB,LOW);
  delay(3000);
  delay (1000);
//  Serial.println(sensorValue);
}/code]
Logged
New Jersey
Offline Offline
Edison Member
View Profile
Get rid of these for a start - the Analog pins are ready to go at startup for reading the ADC:
Code:
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
Quote
Code:
That's a very low limit, just under 5mV on the current sense pin.You'll need a much higher limit than that. What current limit do you want, and what value current sense resistor are you using? Use Ohm's Law to work out the resulting voltage across the current sense resistor, then you can work out the correct value for 'limit'.
Quote
Code:
  delay(5000);
Is this code meant to switch the motor to braking mode if the current is over the limit? If so, you need to use > instead of < in the if-condition.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Offline Offline
Newbie
View Profile
I set it at 1 to see if it worked.  it did and it would work up to 16 but it made no difference to the value when i load up the motor.  it stays at 16.  my motor stalls at 0.5amps.  i'm not using any resistors in the circuit, i'm using the Arduino motor shield, should I being using resistors somewhere in the circuit?  I've got the motor connected to the outputs for the motor and a seperate 6v supply on the board nothing else is wired in.  I'll look up the >instead of< code.
This help is much appreciated, thank you.
Colin
Logged
Offline Offline
Newbie
View Profile
opps understand < not >
Logged
Offline Offline
Newbie
View Profile
I can't get the serial monitor to show any value that relates to the current draw from the motor.  when i test pin A1 with my multimeter it registers a voltage change appropriate to the values listed in the spec 2amps equivalent to 3.3V, i'm getting about .4v.  What do i need to change on the code to read the change in voltage at pin A1 as i load up the motor?
Code:
void loop () {
 // read the value from the sensor:
  sensorValue = analogRead(sensorPin);
  //int sensorValue=analogRead(A1);
  float voltage = sensorValue * (5.0 / 255);
 int limit =.22; //Value that triggers motor to shutoff once it has reached endpoint
  delay(2000);
  Serial.println(voltage);
  if (sensorValue>limit)
  delay(5000);
}/code]
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Code:
int limit =.22;
Is the same as writing
Code:
int limit =0;
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
I've looked at the Motor Shield rev 3 schematic at http://arduino.cc/en/uploads/Main/arduino_MotorShield_Rev3-schematic.pdf and it shows a 0.15 ohm current sense resistor on each channel. So if that's the board you are using, with 0.5A flowing you will get 0.075V at the analog input. That corresponds to an analogRead() result of 15.
Logged
Offline Offline
Newbie
View Profile
but why doesn't the serial monitor change it's value if i load up the motor.  Surely if the motor has load on it at the point the program reads the serial print command it will display the change from the value it would read if the motor had no load?
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
Because limit is 0, and even with no load the current is probably enough to give a current sense reading greater than 0.
Logged
Offline Offline
Newbie
View Profile
Just tried value 10 and 20 and it makes no difference to what the serial monitor writes.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
Why should it?
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
And what exactly does the serial monitor write? Preferably, get it to write the raw value returned by analogRead.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
