Topic: problem: inconsistent microphone reading. (Read 4106 times) previous topic - next topic
makovanx
electret condenser mic to A0 of the analog input.
here is my code:
Code: [Select]
this sketch will test if the electret mic will pick up
signal or input.
the output is generated in the serial monitor(ctrl+shift+m).
the output will show the range of frequencies that the mic
support.
int senseMic = 0
; //analog pin of gizduino
void setup(){
void loop(){
Serial.println(analogRead(senseMic));
the schematic diagram:
the reading in serial monitor:
Code: [Select]
539
535
533
533
533
530
535
672  //i give a continuous input to the mic fro here to..
252
757
136
757
758 //..here
533
532
536
536
546
562
170  //aslo from here to..
487
758
310
758
758
707  //..here
547
548
542
545
546
what should i do or should i add/take to make the reading more consistent?
Grumpy_Mike
I would expect the readings you get. The signal from a microphone is an audio wave not a sound envelope. What are you expecting?
When you say constant input to the microphone what exactly do you mean?
makovanx
good day sir,
i am expecting that when i give an input to the mic,
the reading will give an above 550 value throughout the duration i am giving it an input.
is there something i can do to make it consistent? or its just natural for the mic to give
a low value time to time when i give an input to the mic?
retrolefty
good day sir,
What is the specific form of the input you are giving the microphone? An audio signal is never a 'steady' value, if you ever could look at a audio signal on a oscilloscope it might be more clear to you what you are up against. Taking a single 'spot' reading with a analogRead() command tells one almost nothing about the audio signal. I think you need more understand about AC and DC voltages before proceeding too far in this project.
Lefty
makovanx
what i am trying to make sir is a blow sensor,
so, is it just natural for the reading to go down.?
ahm, i'm making this project at home so i don't have an oscilloscope sir,.
sorry,..
dhenry
What you saw makes sense: the output is a 1/2 Vcc dc + an audio signal. So when the mic isn't blown at, it is just the 1/2 Vcc -> 512 adc readings that you are getting.
When the audio signal comes in, the readings start to deviate from 512 -> which is what you observed.
Grumpy_Mike
You need a circuit called a peak detector to turn the signal from the microphone into the sort of signal you are expecting.
Try a seriese diode and a capacitor to ground before the analogue input, also put a resistor in parallel with the capacitor.
dhenry
With what you have, you can solve the problem easily in software:
Code: [Select]
#define THRESHOLD_BLOWN 100 //threshold when mic is blown
#define MEMORY_MIC 16 //moving average memory
#define COUNT_BLOWN 4 //number of consecutive material deviations
unsigned char isblown(unsigned char mic) {
  unsigned short tmp_adc; //temp variable for adc
  static unsigned short mav_mic=0; //moving average
  static unsigned short mdev_mic=0; //moving deviation
  static unsigned char count_mic=0; //consequetive reads when mic is outside of THRESHOLD_BLOWN
  tmp_adc = analogRead(mic); //read the mic
  mav_mic += (tmp_adc - mav_mic) / MEMORY_MIC; //calculat the moving average
  mdev_mic += ((tmp_adc > mav_mic)?(tmp_adc - mav_mic):(mav_mic-tmp_adc) - mdev_mic) / MEMORY_MIC; //calculate the moving average of deviations
  if (mdev_mic > THRESHOLD_BLOWN) count_mic+=1; //increment mic
  else count_mic = 0; //otherwise, reset
  return (count_mic>COUNT_BLOWN)?1:0;
It does three things:
1) it maintains a moving average of the adc results: essentially a capacitor to block the dc portion of the signal;
2) it detects the amplitude of the ac portion of the signal: so if the mic is blown at, this portion will go up;
3) it then counts the number of times the mic is outside of the levels determined by THRESHOLD_BLOWN and keeps track of it: when the mic returns a high deviation signal over a number of reads (defined by COUNT_BLOWN), the function returns a 1.
So your user code would be something like this:
Code: [Select]
  if (isblown(senseMic)) { //mic is being blown at
    do_something();
    do_something_else();
dhenry
Here is this piece in action:
Code: [Select]
#include <stdio.h>
#include <stdlib.h>
#define MEMORY_MIC 4 //moving average memory
#define DAT_COUNT 52
unsigned short analogRead(unsigned char adc_ch) {
    const unsigned short dat[DAT_COUNT]= {
        539,
        535,
        533,
        533,
        533,
        530,
        535,
        539,
        535,
        533,
        533,
        533,
        530,
        535,
        539,
        535,
        533,
        533,
        533,
        530,
        535,
        539,
        535,
        533,
        533,
        533,
        530,
        535,
        672,  //i give a continuous input to the mic fro here to..
        252,
        757,
        136,
        757,
        758, //..here
        533,
        532,
        536,
        536,
        546,
        562,
        170, //aslo from here to..
        487,
        758,
        310,
        758,
        758,
        707,  //..here
        547,
        548,
        542,
        545,
        546
    static unsigned char index=0;
    index=(index==DAT_COUNT-1)? 0: (index+1);
    return dat[index];
    mdev_mic += (((tmp_adc > mav_mic)?(tmp_adc - mav_mic):(mav_mic-tmp_adc)) - mdev_mic) / MEMORY_MIC; //calculate the moving average of deviations
    printf("count_mic=%4d, tmp_adc = %5d, mav_mic=%5d, mdev_mic=%5d\n", count_mic, tmp_adc, mav_mic, mdev_mic);
int main(void) {
    unsigned char i=0;
    printf("Hello world!\n");
    for (i=0; i<DAT_COUNT; i++) {
    //if (isblown(0)) printf("isblown() = 1\n");
    //else printf("isblown() = 0\n");
    isblown(0);
    return 0;
It ran on Turbo C (my favorite tool to write code for mcus). I wrote the analogRead() piece to replicate the data you got from your microphone - you will need to eliminate it from your code.
Code: [Select]
count_mic=   0, tmp_adc =   535, mav_mic=  133, mdev_mic=  100
count_mic=   1, tmp_adc =   533, mav_mic=  233, mdev_mic=  150
count_mic=   2, tmp_adc =   533, mav_mic=  308, mdev_mic=  168
count_mic=   3, tmp_adc =   533, mav_mic=  364, mdev_mic=  168
count_mic=   4, tmp_adc =   530, mav_mic=  405, mdev_mic=  158
count_mic=   5, tmp_adc =   535, mav_mic=  437, mdev_mic=  143
count_mic=   6, tmp_adc =   539, mav_mic=  462, mdev_mic=  127
count_mic=   7, tmp_adc =   535, mav_mic=  480, mdev_mic=  109
count_mic=   0, tmp_adc =   533, mav_mic=  493, mdev_mic=   92
count_mic=   0, tmp_adc =   533, mav_mic=  503, mdev_mic=   77
count_mic=   0, tmp_adc =   533, mav_mic=  510, mdev_mic=   64
count_mic=   0, tmp_adc =   530, mav_mic=  515, mdev_mic=   52
count_mic=   0, tmp_adc =   535, mav_mic=  520, mdev_mic=   43
count_mic=   0, tmp_adc =   539, mav_mic=  524, mdev_mic=   36
count_mic=   0, tmp_adc =   535, mav_mic=  526, mdev_mic=   30
count_mic=   0, tmp_adc =   533, mav_mic=  527, mdev_mic=   24
count_mic=   0, tmp_adc =   533, mav_mic=  528, mdev_mic=   20
count_mic=   0, tmp_adc =   533, mav_mic=  529, mdev_mic=   16
count_mic=   0, tmp_adc =   530, mav_mic=  529, mdev_mic=   13
count_mic=   0, tmp_adc =   535, mav_mic=  530, mdev_mic=   11
count_mic=   0, tmp_adc =   539, mav_mic=  532, mdev_mic=   10
count_mic=   0, tmp_adc =   535, mav_mic=  532, mdev_mic=    9
count_mic=   0, tmp_adc =   533, mav_mic=  532, mdev_mic=    7
count_mic=   0, tmp_adc =   533, mav_mic=  532, mdev_mic=    6
count_mic=   0, tmp_adc =   533, mav_mic=  532, mdev_mic=    5
count_mic=   0, tmp_adc =   530, mav_mic=  532, mdev_mic=    5
count_mic=   0, tmp_adc =   535, mav_mic=  532, mdev_mic=    5
count_mic=   0, tmp_adc =   672, mav_mic=  567, mdev_mic=   30
count_mic=   0, tmp_adc =   252, mav_mic=  489, mdev_mic=   81
count_mic=   1, tmp_adc =   757, mav_mic=  556, mdev_mic=  111
count_mic=   2, tmp_adc =   136, mav_mic=  451, mdev_mic=  162
count_mic=   3, tmp_adc =   757, mav_mic=  527, mdev_mic=  179
count_mic=   4, tmp_adc =   758, mav_mic=  584, mdev_mic=  178
count_mic=   5, tmp_adc =   533, mav_mic=  572, mdev_mic=  144
count_mic=   6, tmp_adc =   532, mav_mic=  562, mdev_mic=  116
count_mic=   0, tmp_adc =   536, mav_mic=  556, mdev_mic=   92
count_mic=   0, tmp_adc =   536, mav_mic=  551, mdev_mic=   73
count_mic=   0, tmp_adc =   546, mav_mic=  550, mdev_mic=   56
count_mic=   0, tmp_adc =   562, mav_mic=  553, mdev_mic=   45
count_mic=   1, tmp_adc =   170, mav_mic=  458, mdev_mic=  105
count_mic=   0, tmp_adc =   487, mav_mic=  465, mdev_mic=   85
count_mic=   1, tmp_adc =   758, mav_mic=  538, mdev_mic=  118
count_mic=   2, tmp_adc =   310, mav_mic=  481, mdev_mic=  131
count_mic=   3, tmp_adc =   758, mav_mic=  550, mdev_mic=  150
count_mic=   4, tmp_adc =   758, mav_mic=  602, mdev_mic=  151
count_mic=   5, tmp_adc =   707, mav_mic=  628, mdev_mic=  133
count_mic=   6, tmp_adc =   547, mav_mic=  608, mdev_mic=  115
count_mic=   0, tmp_adc =   548, mav_mic=  593, mdev_mic=   98
count_mic=   0, tmp_adc =   542, mav_mic=  581, mdev_mic=   84
count_mic=   0, tmp_adc =   545, mav_mic=  572, mdev_mic=   70
count_mic=   0, tmp_adc =   546, mav_mic=  566, mdev_mic=   58
count_mic=   0, tmp_adc =   539, mav_mic=  560, mdev_mic=   49
The code falsely returned a "blown" signal initially, very similar to a capacitor that's being charged up. Once mav_mic has been correctly established, it triggered reliably, as you can see that the count_mic variable goes up / down with the ac portion of the signal.
The code is a copy-and-paste back to your arduino development, minus the printf() piece in isblown().
makovanx
thank you for the informative reply sir Grumpy_Mike and sir dhenry,..
i will study your suggested hardware & software solution to understand them better,
with this, i hope this project of mine will be up and running soon,..
again, thank you kind sirs,..
