Loading...
Pages: 1 [2]   Go Down
Author Topic: Serial Programming question  (Read 470 times)
Offline Offline
Newbie
View Profile
Now I am trying to read 4bytes of data coming from the ATMega32.
1-sync,2-t,3-h,4-f
 I inserted that while loop after every Serial1.read()
Code:
   if(Serial1.available()>0)
    sync=Serial1.read();
    //delay(500);
    if(sync==0xAA)
      Serial.print("Sensor reading \n");
      while(!Serial1.available())
      digitalWrite(13,HIGH);
      //if(Serial1.read()==B00011010) //Address 1=B00011010
        while(!Serial1.available());
        temp=Serial1.read();
        hu=Serial1.read();
        fcs=Serial1.read();
        digitalWrite(13,LOW);
        if((temp+hu)==fcs)
          Serial.print("Temperature 1 \t");
          Serial.print(temp);
          Serial.print("Humidity 1 \t\n");
          Serial.print(hu);
        Serial.print("Sensor1 Error\n");
It is very slow(not main problem as the sensor updates the data once every second, but still the data received is lot slower and jitter is also high ) and the error rate is too high. Is there any programming improvement to reduce the errors and jitter(speed is secondary)
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Code:
Serial.available() is not a boolean function. Do not use it like one!
Logged
Offline Offline
Newbie
View Profile
Code:
For now it is serving the purpose.
Could you suggest a better alternate instruction to make the arduino wait until the the byte of data is available.
« Last Edit: December 07, 2012, 06:30:03 pm by cyberhawk9 » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Yes. The function returns the number of bytes available to read, NOT just whether there is data to read. If you want to wait for one byte, say so:
Code:
while(Serial.available() < 1) { // Do nothing }
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
The function returns zero (aka false) or not zero (aka true).
In C, that's as good as boolean. It just about embodies the essence, the spirit of C.
Quote
Could be read as "Do not use it like one. Not"    smiley-wink
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
I still think that it is better to be clear in the code what you are waiting for. Changing my example to wait for 4 characters, instead, would be trivial. Changing OPs code to wait for 4 characters is much more involved.
Logged
Offline Offline
Newbie
View Profile
I will change that.
Are there any suggestions to reduce the jitter and errors through programming?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
No. Jitters and error are caused either by the sender getting incorrect data to send, or by interference between the two Arduinos due to excessive distance/environmental factors.
You still haven't answered the question about why you need two Arduinos, nor have you described how far apart they are or what kind of environment they are operating in.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
