Topic: Combining two sketches, help! (Read 2820 times) previous topic - next topic
APieceOfToast
Hi there first post so be gentle please,
I'm trying to combine two sketches, the first is supposed to count the number of times a photo interrupters beam is broken, and the other one is the standard blink program. Both have been tested and both work the way I want them to. When I combine them together and redefine the "setup" and "loop" codes for each program together and then upload them, neither program works.
Here is my count program:
Code: [Select]
const int inPinUp = 6;
const int inPinDown = 7;
int channel = 1;
int buttonUpState = 0;
int buttonDownState = 0;
int prevBtnUp = LOW;
int prevBtnDwn = LOW;
unsigned long lastBtnUp = 0;
unsigned long lastBtnDwn = 0;
int transInt = 50;
  pinMode(inPinUp, INPUT);
  pinMode(inPinDown, INPUT);
  buttonUpState = digitalRead(inPinUp);
  buttonDownState = digitalRead(inPinDown);
  if (buttonUpState == HIGH && prevBtnUp == LOW)
    if (millis() - lastBtnUp > transInt)
    channel++;
    lastBtnUp = millis();
    Serial.println(channel);
  prevBtnUp = buttonUpState;
here is the blink code:
Code: [Select]
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 9;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
and here is my attempt at combining the two codes:
Code: [Select]
void setup (){
  setupCount();
  setupBlink();
void loop (){
  loopCount();
  loopBlink();
int channel = 1;
int transInt = 50;
void setupCount()
void loopCount()
    channel++;
  Blink
// give it a name:
int led = 9;
void setupBlink() {
void loopBlink() {
Any help would be greatly appreciated!
Arrch
The code does something. You're expecting it to do something else. Posting those two pieces of information is how you get help. Saying "it doesn't work" isn't how you get help.
My first thought, though is that you shouldn't be using delay() in your blink code and be using code from the Blink Without Delay example.
PaulS
You are aware that loopCount() will only be called every two seconds, right?
Ditch those delays. Look at the blink with delay example.
Why do you have three setup() type functions? Put all that code in ONE function.
The combine code does something. What that is isn't clear.
Grumpy_Mike
Have a look at this, it tells you about some of the things you have to think about when combining code:-
http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
APieceOfToast
Funnily enough that is what I used to get where I am now.
I will check out the blink without delay example, I din't realize that loopCount() would be called every two seconds.
As to why I have three setup() functions see the above link, I may have interpreted it incorrectly. The tutorial says to redefine setup() and loop() for each program and then define each one under a setup() function.
My bad, by "It doesn't work" I meant that the program does not perform either of the functions intended, as in it does not blink, nor does it count. This may be a result of the delays being in there, I will need to look at the blink without delay.
Your hunch appears to be a solid lead.
Thank you all for the quick replies.
PaulS
Quote
To test that they can play well together, that's fine. Actually merging the code shows more commitment.
So, comment out one of the loopXXXXX() calls in loop. Does that other one work as it did individually? If not, it's a hardware problem.
APieceOfToast
Ok, so I re-did the code using the blink without delay program. Unfortunately the program still does not count the times the beam is broken, or blink. I removed the multiple utterances of setup() and loop().
Here is what I have now:
Code: [Select]
int channel = 1;
int transInt = 50;
// constants won't change. Used here to
// set pin numbers:
const int ledPin =  9;      // the number of the LED pin
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;        // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000;           // interval at which to blink (milliseconds)
 // set the digital pin as output:
 pinMode(ledPin, OUTPUT);
   channel++;
 // here is where you'd put code that needs to be running all the time.
 // check to see if it's time to blink the LED; that is, if the
 // difference between the current time and last time you blinked
 // the LED is bigger than the interval at which you want to
 // blink the LED.
 if(currentMillis - previousMillis > interval) {
   // save the last time you blinked the LED
   // if the LED is off turn it on and vice-versa:
   if (ledState == LOW)
     ledState = HIGH;
     ledState = LOW;
   // set the LED with the ledState of the variable:
   digitalWrite(ledPin, ledState);
It compiles, but that doesn't mean I did ANYTHING right, and I'm waaaay outside of my comfort zone.
Edit: I have not checked the blink without delay code, but before I started combining both codes functioned exactly as I expected them to.
Arrch
Why are you calling Serial.begin() and setting pinModes inside your loop function. In the Arduino IDE, press Ctrl+T to fix the atrocious formatting.
PaulS
Quote
More importantly, why are you doing them only under such specific circumstances? It seems clear that you do not understand what either sketch was doing.
APieceOfToast
anyway I went in to fix the formatting and move my Serial.Begin() and pinModes outside of my loop function, and well suddenly the Arduino IDE wants me to empty my loop function as it refuses to compile and instead progressively tells me that everything from the bottom to top of my code is wrong and I have no idea what happened.
Here's where I'm at now:
Code: [Select]
int channel = 1;
int transInt = 50;
// set pin numbers:
        channel++;
      // blink the LED.
      ledState = HIGH;
      ledState = LOW;
I'm sorry if I cause any more brain damage through my abuse of the code.
Arrch
#10
Dec 08, 2012, 12:57 am Last Edit: Dec 08, 2012, 01:00 am by Arrch Reason: 1
Your loop function is inside your setup function. That's what the compiler doesn't like (among other things).
If you're THAT far outside of your comfort zone, I recommend going through a few more of the examples to understand the basics of the structure and syntax for the programming language. You seem to be blindly moving stuff around hoping that something magical happens and it compiles.
PaulS
If you make a habit of putting each { on a new line, instead of on a line with other code, and of using Tools + Auto Format periodically, you'll see the extra braces you have, and the missing ones.
Code: [Select]
  { // <-- What is this for?
Code: [Select]
Every if statement should be followed by { and }. They take very little effort to type, and ones that are not strictly needed cause the compiler no problems. They DO help make it clear what the if statement controls.
Code: [Select]
I want to print something, then I want to get ready to print. Can you not see that this is a problem?
You've been told, more than once, that Serial.begin() and pinMode() belong in setup(), not loop().
Why is loop() now embedded in setup?
Print your code. Take a pencil and play connect the dots with the { and }. Understand what each one introduces and what each one closes out.
APieceOfToast
Unfortunately I am that far outside of my comfort zone, I started playing with arduino's and coding a couple weeks ago and was barely comfortable blinking LED's on and off, and then my work asked me to work on a project involving arduino and coding. The result is the above code, and I suppose that to some extent that I am "blindly moving stuff around hoping that something magical happens and it compiles" however I do try to move things where I believe they should be according to my extremely limited experience.
Having said my bit I really appreciate the help I'm getting from this forum, I will certainly print my code and connect my brackets. I thought I had that covered but clearly not.
It may be a while before I am able to update my progress and I would greatly appreciate it if you two would keep an eye out for that.
dhenry
A few approaches:
1) incorporate the blinking code into your other code, with a ticker (through millies): something like this
Code: [Select]
  if ((millies() - blinking_millis) > DESIRED_TIME) { //test to see if desired time has passed
    blinking_millis -= DESIRED_TIME; //reset blinking millis
    blink_led(); //blink my led
2) use an interrupt to blink the led - nothing in the main loop
3) or to use an interrupt to detect a broken light beam.
PaulS
Code: [Select]
Minus?
