Author Topic: sending sms on function  (Read 229 times)
London-UK
I have a keypad that works of a passcode. I also have a door contact plus gsm that sends an sms when the door is opened. Both of these at present are working *separately.
What I need is for the door contact to only send sms when the system is set. The system is set via the keypad. I have had the code for the doorState in the (Loop function) and tried removing it from their and creating its own (doorState function). Which I then tried to call from the systemSet function by putting in doorState();. But as expected it only runs once, since its no longer in the "LOOP".
So I think I need to leave the "doorState" in the (Loop function) and add code to it their to look at the (checkPIN function). Is this the correct way to do it.
here is the code snippet of these function.
void systemSet()
  systemSetTone();
  lcd.print ("   System Set   ");
void systemUnSet()
  systemUnSetTone();
  lcd.print ("  System Unset  ");
//------------------------------PASSWORD-CODE-SECTION-------------------------------
void checkPIN()
  int correct = strcmp(attempt, PIN);
  if (correct < 0)
    systemUnSet();
  else if (correct == 0)
    systemSet();
  else if (correct > 0)
    systemUnSet();
  return;
//------------------------------KEYPAD-CHECKING-------------------------------------
void readKeypad()
  char key = keypad.getKey();
  if (key != NO_KEY)   // only do something if a key was pressed
    fromKeypad++; //Each time there is a character received, increment the counter:
    lcd.setCursor(fromKeypad-1, 1);
    lcd.print(key);
    switch(key)// look for the special keys to initiate an event
    case '*':
      z=0;
      fromKeypad = 0;
      break;
    case '#':
      delay(100); // for extra debounce
      fromKeypad = 0;
      lcd.clear();
      checkPIN();
      break;
    default:
      attempt[z]=key;
      z++;
      attempt[z] = '\0';
      KeyPadTone();// play a beep to acknowledge that key pressed
  readKeypad();
//-------------------doorState------------------------------------------------------
  static bool DoorIsClosed=true; // Let's assume it's closed for starting
  static bool SMSSent=false;     // Tells us whether we've sent an SMS for the latest instance of the door being open
  int currDoorState = digitalRead(doorContactPin); //current door state is the current condition of the door contact pin.
  if(currDoorState != prevDoorState)   //  checked against above statement. Door was closed and is now open or door was open and is now closed
    if(currDoorState == LOW)
      DoorIsClosed=true; // Door is now closed
      DoorIsClosed=false; // Door is now open
      doorOpenTime = millis();
    SMSSent=false; // Door state changed, we may have a new opportunity to send SMS
  prevDoorState = currDoorState; //previous door state is NOW the current door state.
  if(!DoorIsClosed && !SMSSent)  // Now see if the door is open TRUE if the door is not closed and sms is not sent
    if(millis() - doorOpenTime >= time_threshold) // if the overall time minus the door open time is greater then time threashold send sms
      sendSMS();
      SMSSent=true;
Seattle, WA USA
Seattle, WA USA
All that code after loop() is not in a function. So, no.
The systemSet() and systemUnset() functions don't actually do anything. They need to, at a minimum set/clear a flag that says that the alarm is/is not set.
London-UK
It was before I put it back in loop.
so I need to leave it where it is and create an interupt is that correct.
and does the interupt go i the systemSet()/ systemUnset  function.
Seattle, WA USA
Seattle, WA USA
No. Interrupts are external events that need to be handled immediately, like serial data arriving. Nothing about your program needs to be dealt with immediately. A few milliseconds later will be fine. So, polling is good enough.
London-UK
how do you pole?. is the example sketch BlinkWithoutDelay using polling? thats comes with the arduino software?
/* Blink without Delay
 Turns on and off a light emitting diode(LED) connected to a digital
 pin, without using the delay() function.  This means that other code
 can run at the same time without being interrupted by the LED code.
 The circuit:
 * LED attached from pin 13 to ground.
 * Note: on most Arduinos, there is already an LED on the board
 that's attached to pin 13, so no hardware is needed for this example.
 created 2005
 by David A. Mellis
 modified 8 Feb 2010
 by Paul Stoffregen
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used here to
// set pin numbers:
const int ledPin =  13;      // the number of the LED pin
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;        // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000;           // interval at which to blink (milliseconds)
  // set the digital pin as output:
  pinMode(ledPin, OUTPUT);
  // here is where you'd put code that needs to be running all the time.
  // check to see if it's time to blink the LED; that is, if the
  // difference between the current time and last time you blinked
  // the LED is bigger than the interval at which you want to
  // blink the LED.
  unsigned long currentMillis = millis();
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    previousMillis = currentMillis;
    // if the LED is off turn it on and vice-versa:
    if (ledState == LOW)
      ledState = HIGH;
      ledState = LOW;
    // set the LED with the ledState of the variable:
    digitalWrite(ledPin, ledState);
from previous
do I leave the doorState in the void loop. or do I need to put it in a function.
  readKeypad();
      sendSMS();
      SMSSent=true;
thanks in advance
Seattle, WA USA
Seattle, WA USA
how do you pole?
Polling is reading sensors on every pass through loop.
Either one, but that code needs to be in some function.
London-UK
in general terms, I'm even more confused now with what seems to be a wealth of options.
As I understand, If I leave the part of the code in the void loop I need it to call to some piece of code in another function to test a condition. Based on the result of that condition. The part of the void loop  that runs the doorState code will do either something or something else.
It looks kind of simple but I can't code what I am trying to achieve in my head. I have no logic smiley-red
Are there really more ways to skin a cat!
Seattle, WA USA
Seattle, WA USA
Always. There are ways to skin a dog, too. And a deer, and a variety of other animals.
I suspect that is because you are trying to write the whole program at once.
What I like to do is write a whole lot of comments in loop, describing what the whole program is going to do. Then, in between some of the comments, I write some code to perform a specific task. When that works, I write some more code. After a while, loop() is too long, so I move some working code into functions.
Sometimes I get stuck on how to do something, so I create a function that does nothing, and call it in the place I'm stuck. I just have it return a value that makes it seem like it actually did something complex.
Then, I'll go back and make that function do what it is supposed to do, one step at a time. Each time I get stumped, I write a lot of comments.
London-UK
Thats Irony smiley-wink
