Topic: [Solved] Conversion to String (Read 981 times) previous topic - next topic
Xendor
Dec 08, 2012, 01:40 am Last Edit: Dec 09, 2012, 09:00 am by Xendor Reason: 1
[Problem solved]
hi all guys..
well I got arduino uno r3 and ehternet shield, im trying with arduino as server and I have mount a HTML page here, my problem is I can't get a code from the html to var, look this:
const char id= const char(cliente.print("document.form1.user.value"));
im trying this
I want get a data becuase I maked a login.. then Im tryied to put some like JS and php but dont work that for me :/
anyway I tried to get the user and psw in this case how im experiment whit this just I put the "user" and I want to put the "user"(ID to login) and give to var "ID" but I know that I'm doing that so bad.. Im here for any solution I have 1 week trying to resolve this.
sorry for my english is not my primary language. for more info just call it and I can give you.. that's all thx!
[Solution]
in html code I used function "onclick" then can write in the link the user entered. inside arduino code have an IF:
int OPC = readString.indexOf("Log="); //Read the link to 'Log='
if(readString.substring(OPC,OPC+5)=="Log=T")
{  do something   } //in this case write Index.html
thx for all help guys... so now I have a new problem :/ ---> http://arduino.cc/forum/index.php/topic,136570.msg1025897.html#msg1025897
PaulS
Have you looked at what the print() method for whatever class cliente is an instance of returns? It is most likely NOT something that can be meaningfully cast to a const char.
The cliente.read() method MIGHT be what you are needing to use.
Xendor
okay then I need try with: String id= String(cliente.read("value1")); or String id= String(cliente.read("document.form1.user.value"));
I'm right sure? or Im doing something wrong?
anyway Im tried with: String id= String(cliente.read("value1")) and sketch throw "no matching function for call to 'EthernetClient::read(const char [7]'" :/
I cant undesrtand that can you guide me a little please?
PaulS
The read() method doesn't take any arguments. It knows where to read from. It returns the value that it read. You need to store those characters somewhere, until you know that you have read a whole packet.
PeterH
There are two parts to the problem.
You need to design the page so that when the user enters the name+password and requests a login, the page submits the values in an HTTP request.
Then when receiving the HTTP request you need to parse the request to recognise that it is a login request and extract the name+password values that were submitted.
You should have no trouble finding existing examples of both parts, but the code you quoted doesn't look anywhere close so I suggest that you start by looking at how other people solve the problem.
I only provide help via the forum - please do not contact me for private consultancy.
Xendor
well.. unfortunately I was struggling to find examples, that's why I came here as a last option, because I have run out of ideas, also the english is not my first language then I took longer to understand something.
Docedison
Is there a section here in the forum that does use your language? There are many different places in this forum that do use other languages. I do believe that Google is multilingual, If it isn't let me know and I'll do something about it promptly.
Bob
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
zoomkat
Simple server test code that captures the contents of a text box and looks in it for info, and changes an arduino pin start.
Code: [Select]
//zoomkat 12-08-12
//get submit box code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html or use a '
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84);; //server port
String readString;
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  //enable serial data print
  Serial.println("server text box test1"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //see what was captured
          //now output HTML data header
          client.println("Content-Type: text/html");
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>HTML form GET example</H1>");
          client.println("<FORM ACTION='/' method=get >"); //uses IP/port of web page
          client.println("Pin 5 'on' or 'off': <INPUT TYPE=TEXT NAME='LED' VALUE='' SIZE='25' MAXLENGTH='50'><BR>");
          client.println("<INPUT TYPE=SUBMIT NAME='submit' VALUE='Change Pin 5!'>");
          client.println("</FORM>");
          client.println("<BR>");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          if(readString.indexOf("on") >0)//checks for on
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
