Topic: Continuous servo running irregular at low speed? (Read 1 time) previous topic - next topic
Chilus
Dec 08, 2012, 04:08 pm Last Edit: Dec 08, 2012, 04:10 pm by Chilus Reason: 1
Hi all,
I'm having a problem with my continuous servo's. They move irregular and not smooth, especially at lower speeds.
I apply an external powersource of 6V and use simple code with writeMicroseconds to test it. However, it seems that the servo is accelerating and at a certain point it jumps to a lower speed.
Video of problem explains enough I think: http://www.youtube.com/watch?v=c9VEknZ7IjQ&feature=youtu.be
It's not the problem of the servo being broke, as it happens with multiple.
Hope somebody knows what the problem could be.
Thanks!
Code: [Select]
#include <Servo.h>
Servo myservo1;
 myservo1.attach(9);
 myservo1.writeMicroseconds(1520);
retrolefty
#1
Dec 08, 2012, 05:29 pm Last Edit: Dec 08, 2012, 05:38 pm by retrolefty Reason: 1
The myservo1.writeMicroseconds(1520); sets the stop state for the servo and you will have to find the exact microsecond value for each specific servo you use for it's exact stop value. It's nominally 1500 usec but will vary a little + or - for each servo.
Lefty
zoomkat
Servo test code you might try to see if the speed issue occurrs with this code.
Code: [Select]
//zoomkat 11-22-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
  //myservoa.writeMicroseconds(1500); //set initial servo position if desired
  myservoa.attach(6);  //the pin for the servoa control
  myservob.attach(7);  //the pin for the servob control
  myservoc.attach(8);  //the pin for the servoc control
  myservod.attach(9);  //the pin for the servod control
  Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
  //expect single strings like 700a, or 1500c, or 2000d,
  //or like 30c, or 90a, or 180d,
  //or 30c,180b,70a,120d,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
          if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.write(n);
          if(readString.indexOf('b') >0) myservob.write(n);
          if(readString.indexOf('c') >0) myservoc.write(n);
          if(readString.indexOf('d') >0) myservod.write(n);
         readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Chilus
Hi!
@Lefty,  I am well aware of this fact that each servo has it's own stop value, but this was not my problem. My problem occures when I want to drive my servo slowly, so with a value close to the stop value. When I do this it starts of slow but it speeds up which it shouldn't suppose to do. The speed is irregular at almost every speed except for the maximum speed. It's strange, it slows down and speeds up, slows down and speeds up.
@zoomkat, Thanks for the help but the code you gave didn't work.
I figured that it might have to do something with the servo circuit itself. I think the controlling mechanism malfunctioning. It almost seems like the internal capacitor of the servo are getting 'filled' which give the acceleration during the movement. What I did was 'fooling' the servo by the following code:
Code: [Select]
  myservo1.writeMicroseconds(1510);
  myservo1.writeMicroseconds(1505);
This resulted into a smooth, slow and steady movement BUT now the servo get's hot after a moment. I think due to the quick sequence of writeMicrosecond commands in the void loop the pulsewidth is being distorted, which causes the pulsewidt to be larger than 2.4ms (basically the limit for every servo).
Any thoughts on this?
Chilus
Resolved! I guess
The trick with writing the microSeconds in sequence worked.
I also have the feeling that the heat is less when putting the sequence of commands in a for loop
This workaround works good enough for me.
In the end it was a simple solution/trick, but I couldn't find anybody with similar problems.
Cheers,
Code: [Select]
  for (int i=0; i<6; i+=5) {
  myservo1.writeMicroseconds(1490+i);
zoomkat
Quote
Heat? If the servos are hot and not under much load, then you probably don't have the servo and arduino grounds connected together properly.
