Topic: I2C communication (Read 769 times) previous topic - next topic
Fortware
Dec 11, 2012, 09:55 am Last Edit: Dec 11, 2012, 03:14 pm by Fortware Reason: 1
Hi, I run across a problem about I2C communication .
When I send sevrial (at least two byte) byte datas
from slave board to main board at the same time ,the
main board only can read the first byte ,can't receive
the rest of it .Here is the code:
main_read:
Code: [Select]
#include <Wire.h>
byte x,y;
   Wire.begin(1);
   Serial.print(9600);
    Wire.requestFrom(1,2) ;
    while(Wire.available()>0)
        x=Wire.read();
        y=Wire.read();
    Serial.println(x);
    Serial.println(y);
Slave_write:
Code: [Select]
#include <Wire.h>
byte a=12,b=56;
     Wire.begin(1);
     Wire.onRequest(requestEvent);
 Serial.println("Hello world !");
 Serial.print(a);
 Serial.print(b);
 delay(100);
 void requestEvent()
     Wire.write(a);
     Wire.write(b);
What's wrong with it ? I'm confunsed about it .
Nick Gammon
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
Read this:  http://www.gammon.com.au/i2c
Code: [Select]
void requestEvent()
      Wire.write(a);
      Wire.write(b);
Your double-spacing is very distracting. You aren't writing an essay.
Inside a request event you can only (successfully) do one write. If you want to write two bytes, do it as a single write, eg.
Code: [Select]
void requestEvent()
   byte buf [2] = { a, b };
   Wire.write(buf, sizeof buf);
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Nick Gammon
Code: [Select]
main_read:
#include <Wire.h>
byte x,y;
    Wire.begin(1);
The master and slave should not have the same address. Each device on the I2C bus needs a different address. You have used 1 for both of them.
More info:
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
