Topic: DHT22 Can i share the data pin ?? (Read 1 time) previous topic - next topic
invader7
Hello , i want to get measurements from this https://www.sparkfun.com/products/10167? , it works with my arduino , but i want to know if i can share the data pin and connect it to my raspberry pi , in order to read the measurements from there too.... Is that possible ? Does anyone tried it ?
RIDDICK
hi!
u could use 2 devices that communicate with that DHT22,
if u can make sure, that they dont try that at the same time... :)
that 1-wire protocol doesnt tolerate communication collisions...
u could try to do it like ethernet does it:
1. carrier sense: a unit, that wants to talk, looks at the line for some time in order to c if communication is going on right now...
2. collision detect: a talking unit reads the line during a write request in order to c if someone "overwrites" its communication...
have fun...
-Arne
dc42
In principle, yes. However, there are the following considerations:
1. The Rasperry Pi uses 3.3V signal levels. Most Arduinos use 5V signal levels. So you will have to either use a 3.3V Arduino, or be very careful not to let the Arduino drive more than 3.3V on to that line. Or use a buffer chip or diode and 2 pins - see point 3 below.
2. Both the Arduino and the Pi need to drive the device using an open-collector output. I know how to do this on the Arduino, but not on the Pi.
3. If either the Arduino or the Pi is powered down, the other will not be able to read from the device. This can be solved, but you would need to use 2 I/O pins per device, an open-collector buffer chip and a couple of diodes.
invader7
Let arduino "read" the sensor and then inform raspberry http://www.doctormonk.com/2012/04/raspberry-pi-and-arduino.html
I think its the best/safe way for me...
Thanks !
dc42
Yes, if the Arduino will always be powered up when you want the Pi to read the sensor, that's a better way.
