Loading...
Pages: [1]   Go Down
Author Topic: Temperature sur LCD  (Read 677 times)
Offline Offline
Newbie
View Profile
Voila, mon premier montage, l'affichage de la temperature sur un LCD et sur le moniteur serie...
Un debut pour ma prochaine station météo...
Des bouts de codes recuperes dans les exemples, sur le net...
Modification apportées en fonction du capteur de temp que j'ai et qui differe de celui de l'exemple, un LCD pas cher et donc peu lisible...
Commentaires bienvenus.
Code :
Code:
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//MCP9701E-TO Pin Variables
int sensorPin = 0; //the analog pin the MCP9701E's Vout (sense) pin is connected to
//the resolution is 19.5 mV / degree centigrade with a
//400 mV offset to allow for negative temperatures
* setup() - this function runs once when you turn your Arduino on
* We initialize the serial connection with the computer
    // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("Temperature");
Serial.begin(9600); //Start the serial connection with the computer
//to view the result open the serial monitor
void loop() // run over and over again
//getting the voltage reading from the temperature sensor
int reading = analogRead(sensorPin);
// converting that reading to voltage, for 3.3v arduino use 3.3
float voltage = reading * 5.0;
voltage /= 1024.0;
// print out the voltage
Serial.print(voltage); Serial.println(" volts");
// now print out the temperature
float temperatureC = (voltage - 0.4) * 51; //converting from 19.5 mv per degree with 400 mV offset
//to degrees ((volatge - 400mV) times 100)
Serial.print(temperatureC,1); Serial.println(" degres C");
// set the cursor to column 0, line 1
  // (note: line 1 is the second row
  lcd.setCursor(0, 1);
  // print the Temperature:
  lcd.print(temperatureC,1);
delay(5000); //waiting 5 seconds
« Last Edit: December 09, 2012, 12:48:09 pm by Jean-François » Logged
France
Offline Offline
Edison Member
There is an Arduino for that
View Profile
Merci de faire partager ton expérience.
Juste 2 remarques:
 1) les images plus petites (800x600 selon la charte du site)
 2) le programme entre balises
Code:
  (bouton # dans la barre d'outils de la page de saisie des posts)
Logged
Offline Offline
Jr. Member
View Profile
Salut
Félicitation pour ton premier montage.
Tu dis, LCD peu lisible. Sur ta photo, on dirait que le "backlight" n'est pas en fonction.
Est ce le cas?
Logged
Offline Offline
Newbie
View Profile
Code:
Code :
  lcd.begin(16, 2);
voltage /= 1024.0;
« Last Edit: December 09, 2012, 12:55:57 pm by laurentjeuxlille » Logged
Offline Offline
Newbie
View Profile
Salut
Est ce le cas?
Bonne question pour le backlight... aucune idée en fait... j'ai juste un potentiometre 10k pour regler le texte, mais le backlight je ne sais pas. Peut etre une histoire de jumper au dos, j'ai vu ca dans le datasheet, mais ne sachant pas dans quoi je me lancais, je n'y ai pas touché. Une aide de ton côté ?
Merci
Logged
Forum Moderator
Geneva
Offline Offline
Faraday Member
Yoplait... le pt'it suisse
View Profile
WWW
Tu n'as pas tout lu.....
Code:
Logged
MacBook intel core 2 duo  os X snow Leopard 10.6
eMac PPc G4  os X Leopard 10.5
powerbook G4 os X Leopard 10.5
imac PPC G3 os X Panther 10.3.9
Arduino Diecimila
Arduino Mega
Arduino Standalone
Arduino 1307.04
Offline Offline
Newbie
View Profile
Euh, si, le code est dans les quote... il me semble. La ref du ldc est LCD16216SBH si moyen de modifier le backlight, je suis preneur.
« Last Edit: December 09, 2012, 12:37:56 pm by laurentjeuxlille » Logged
Forum Moderator
Geneva
Offline Offline
Faraday Member
View Profile
WWW
Pas lors de mon derniers message.....  smiley-mr-green elle est facile celle là...
Autrement c'est pas entre quote qu'il faut mettre, mais code le bouton avec # .... voilà, voilà  smiley-lol
Logged
Arduino Diecimila
Arduino Mega
Arduino Standalone
Arduino 1307.04
Offline Offline
Newbie
View Profile
je vais y arriver !
sinon une info, il me semble qu'il faut connecter les pin 15 et 16 pour utiliser le backlight...
Logged
Forum Moderator
Geneva
Offline Offline
Faraday Member
View Profile
WWW
Oui :
http://www.mon-club-elec.fr/pmwiki_mon_club_elec/pmwiki.php?n=MAIN.TechniquePreparationLCD
Logged
Arduino Diecimila
Arduino Mega
Arduino Standalone
Arduino 1307.04
Offline Offline
Newbie
View Profile
Yep, connection cathode/anode et  !!!!!!!!!!!!!!!!!! lumière.
Tout de suite on voit mieux.
Merci
Logged
Forum Moderator
Geneva
Offline Offline
Faraday Member
View Profile
WWW
C'est bientôt Nowelll...  smiley-lol
Logged
Arduino Diecimila
Arduino Mega
Arduino Standalone
Arduino 1307.04
Pages: [1]   Go Up
Print
Jump to:
