hi
for robtillaart:Can you tell what values you expected and what you got?Here are the data:
there is an increase in temperature due to the fact that I heat the sensor fingertips.
16.41 degrees C
0.65 volts
14.94 degrees C
0.68 volts
17.87 degrees C
0.67 volts
17.38 degrees C
0.69 volts
18.85 degrees C
0.67 volts
17.38 degrees C
0.67 volts
17.38 degrees C
0.71 volts
21.29 degrees C
0.71 volts
21.29 degrees C
0.72 volts
22.27 degrees C
0.72 volts
22.27 degrees C
0.74 volts
24.22 degrees C
0.74 volts
24.22 degrees C
0.74 volts
24.22 degrees C
0.74 volts
24.22 degrees C
0.72 volts
22.27 degrees C
0.74 volts
23.73 degrees C
0.75 volts
25.20 degrees C
0.73 volts
23.24 degrees C
0.75 volts
24.71 degrees C
0.76 volts
26.17 degrees C
0.76 volts
26.17 degrees C
0.73 volts
22.75 degrees C
0.74 volts
24.22 degrees C
0.75 volts
25.20 degrees C
0.76 volts
26.17 degrees C
they are not super stable but it illustrates the reality.
I add a ceramic capacitor in parallel with only one sensor and the arduino and values are much more stable than that.
How do you power the system? USB / battery / other?[I use a 5v dc supply, 1 A, I do not use the USB cable for the arduino and the sensor will be a 250 'of the computer.
Can you post your electric scheme?I started with this tutorial:
http://learn.adafruit.com/tmp36-temperature-sensor/overviewHere is the datasheet:
http://www.analog.com/static/imported-files/data_sheets/TMP35_36_37.pdffor MarkT indeed, the tmp36 is sensitive to electrostatic waves. I test by adding a ceramic capacitor 0.1 uf without Ethernet scheild and values are more stable. I have not tested the Ethernet scheild. I wanted to make the circuit of Figure 32 of the datasheet because it is suppose to help stop interference, but I do not understand how to connect the circuit to the wire ... because it has only 3 pin and 2 wire ...
are you'd do?
In any case, thank you all 2
Emmanuelle
