Loading...
Pages: [1]   Go Down
Author Topic: Arduino Due and tone()  (Read 1241 times)
Poland, Lodz
Offline Offline
Newbie
View Profile
I wanted to ask if standard tone function works on Arduino Due board? I bought Arduiono week ago, and built all the simple projects with LEDs etc. and now I wanted to use buzzer in project. I connected the circuit like in  http://arduino.cc/en/Tutorial/Tone but when I choose upload I get the message "error: 'tone' was not declared in this scope".
When I change the board to AVR (like Arduino Due) it compiles, so how can I use buzzer with my Arduino Due?
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Hi!.
Has far has I can see, tone library is still disabled. I think you have to wait in case you don't know how to mess with timers. smiley-wink
Logged
Offline Offline
Jr. Member
View Profile
here's a monolithic proof-of-concept of tone()
Code:
  Melody on pin 8 of DUE
// notes in the melody:
int melody[] = { 262,196, 196, 220, 196, 0,  247, 262
  /*NOTE_C4, NOTE_G3,NOTE_G3, NOTE_A3, NOTE_G3,0, NOTE_B3, NOTE_C4*/ };
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations[] = {
  4, 8, 8, 4,4,4,4,4 };
  // iterate over the notes of the melody:
  for (int thisNote = 0; thisNote < 8; thisNote++) {
    // to calculate the note duration, take one second
    // divided by the note type.
    //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
    int noteDuration = 1000/noteDurations[thisNote];
    tone(8, melody[thisNote],noteDuration);
    // to distinguish the notes, set a minimum time between them.
    // the note's duration + 30% seems to work well:
    int pauseBetweenNotes = noteDuration * 1.30;
    delay(pauseBetweenNotes);
    // stop the tone playing:
    noTone(8);
  delay(3000);
 Tone generator
 v1  use timer, and toggle any digital pin in ISR
   funky duration from arduino version
   TODO use FindMckDivisor?
   timer selected will preclude using associated pins for PWM etc.
    could also do timer/pwm hardware toggle where caller controls duration
// timers TC0 TC1 TC2   channels 0-2 ids 0-2  3-5  6-8     AB 0 1
// use TC1 channel 0
#define TONE_TIMER TC1
#define TONE_CHNL 0
#define TONE_IRQ TC3_IRQn
// TIMER_CLOCK4   84MHz/128 with 16 bit counter give 10 Hz to 656KHz
//  piano 27Hz to 4KHz
static uint8_t pinEnabled[PINS_COUNT];
static uint8_t TCChanEnabled = 0;
static boolean pin_state = false ;
static Tc *chTC = TONE_TIMER;
static uint32_t chNo = TONE_CHNL;
volatile static int32_t toggle_count;
static uint32_t tone_pin;
// frequency (in hertz) and duration (in milliseconds).
void tone(uint32_t ulPin, uint32_t frequency, int32_t duration)
const uint32_t rc = VARIANT_MCK / 256 / frequency;
tone_pin = ulPin;
toggle_count = 0;  // strange  wipe out previous duration
if (duration > 0 ) toggle_count = 2 * frequency * duration / 1000;
else toggle_count = -1;
if (!TCChanEnabled) {
  pmc_set_writeprotect(false);
pmc_enable_periph_clk((uint32_t)TONE_IRQ);
TC_Configure(chTC, chNo,
TC_CMR_TCCLKS_TIMER_CLOCK4 |
TC_CMR_WAVE |         // Waveform mode
TC_CMR_WAVSEL_UP_RC ); // Counter running up and reset when equals to RC
chTC->TC_CHANNEL[chNo].TC_IER=TC_IER_CPCS;  // RC compare interrupt
chTC->TC_CHANNEL[chNo].TC_IDR=~TC_IER_CPCS;
NVIC_EnableIRQ(TONE_IRQ);
                         TCChanEnabled = 1;
if (!pinEnabled[ulPin]) {
pinMode(ulPin, OUTPUT);
pinEnabled[ulPin] = 1;
TC_Stop(chTC, chNo);
                TC_SetRC(chTC, chNo, rc);    // set frequency
TC_Start(chTC, chNo);
void noTone(uint32_t ulPin)
TC_Stop(chTC, chNo);  // stop timer
digitalWrite(ulPin,LOW);  // no signal on pin
// timer ISR  TC1 ch 0
void TC3_Handler ( void ) {
TC_GetStatus(TC1, 0);
if (toggle_count != 0){
// toggle pin  TODO  better
digitalWrite(tone_pin,pin_state= !pin_state);
if (toggle_count > 0) toggle_count--;
noTone(tone_pin);
Logged
Pages: [1]   Go Up
Print
Jump to:
