Topic: Leonardo doesn't talk to serial monitor (Read 3838 times) previous topic - next topic
wmassano
I have tried with two leonardos to get some serial I/O with the monitor and so far nothing. I can upload programs (blink, etc). When I upload the following with the while enabled, I get nothing--no serial output, no blinking. If I comment out the while, the led blinks. Any suggestions? (besides going back to the uno)
//Leonardo test 1 -- check serial i/o
void setup(){
  pinMode(13,OUTPUT);
//  while(!Serial);
void loop(){
  int i;
  Serial.println("Ready:");
  for(i=1;i<11;i++) {
    digitalWrite(13,HIGH);
    Serial.println(i);
    digitalWrite(13,LOW);
    delay(200);
nickgammon
The example code for the Leonardo serial port requires you to wait, for example:
//Initialize serial and wait for port to open:
 while (!Serial)  { }
Add in the line after Serial.begin and it should work better.
wmassano
Already tried it. It still doesn't work. Whenever the while is enabled, the program never gets out of setup. Yet comm is okay since I can upload programs. I am at a loss.
nickgammon
Try a higher baud rate? I am using 115200 with mine. It gets converted into USB anyway.
wmassano
Tried higher baud rate, still nothing. I am going to try an xp machine (this has been on Windows 7 up to now)
wmassano
UPDATE
The leonardo talks to the serial monitor on an XP machine. So my question is now: How do I get it to talk the serail monitor on my windows 7 machine????
mk3
Do you need brackets after this line?
your code above
while(!Serial);
like this instead
while(!Serial){}
wmassano
It works either way. In any case, the problem appears to be with windows 7. The leonardo communicates with an XP laptop, but not windows 7 via the serial monitor. I can upload to it with Win 7.
marklar
This may sound odd, but try changing this setting in your Serial object in your application:
RtsEnable =True
and try again.
I found the same issue on my (arg - Vista) machine, where it would work fine when talking with the Arduino serial monitor, but not my application.  I created a simple print and receive set of apps, and they didnt work.  I then updated the RtsEnable setting and amazed it started working.
Hope that helps
wmassano
RtsEnable =True
and try again.
I'm not sure it applies. The problem is between the leonardo and the arduino serial monitor. Where would I put the code you suggest? It looks like code for an external program. Agian it is apparently a Windows 7 problem because I can see the leonado in XP.
marklar
Ah - in my case the serial monitor was working, just not my application.
wmassano
I am going to start a new thread to be more specific. Please look for that thread and do not answer this one. Thanks
