Loading...
Pages: [1]   Go Down
Author Topic: How to set the cursor on the LCD using a variable?  (Read 630 times)
Offline Offline
Newbie
View Profile
 I need to have the cursor move on my LCD based off a variable but what I am trying doesn't work. Is it possible to set the lcd cursor with a variable in the positions?
Here is what won't work for me:
  lcd.setCursor(**varibale goes here**, 0);
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Show what you really tried, not:
Code:
Do you get a compile error, or does it compile but not do what you expect?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Here is a line of code from a program of mine:-
Code:
    lcd.setCursor(4 + menuTitle[m].length(), 1);
That is using a variable to set a cursor.
Post all you code using the code tags so we can see what you are doing wrong.
Logged
Offline Offline
Newbie
View Profile
Code:
int set;
char ch;
  delay(5000);
   /////////////////////////String 1 length//////////////////////////////////
   if( Serial.available() ) {
   ch = Serial.read();
   set = ch;
   lcd.setCursor('set', 0);
Logged
North Queensland, Australia
Offline Offline
Edison Member
View Profile
WWW
'set' is a multi byte character constant, "set" is a string.
What you want is just the variable:
Code:
lcd.setCursor( set, 0);
Logged
Offline Offline
Newbie
View Profile
lcd.setCursor(set, 0) doesn't work eiter, i'm getting no print out at all.
Logged
Dallas, TX USA
Offline Offline
Edison Member
View Profile
lcd.setCursor(col, row) does what it sounds like. Sets the cursor position on the lcd.
The next character printed will be placed at that location.
Your code never prints any characters which is why you never see anything.
It reads a character from the serial port then uses the numeric code of that character to
set the cursor position to that column on row zero.
Have quick read of the LiquidCrystal functions to get a better feel of the
routines available to see what will do what you want.
http://arduino.cc/en/Reference/LiquidCrystal
--- bill
Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
So now you showed us what you have and what is "not working", what is it that you want? You sound like a customer scrolling into a shop and just can't describe to the clerk what you are in the store for. You won't be treated nicely after a while.
Logged
Dallas, TX USA
Offline Offline
Edison Member
View Profile
Bruce,
One thing you might not be aware of is by default the actual cursor is invisible.
If you want to see the cursor the cursor() function will turn it on.
--- bill
« Last Edit: December 09, 2012, 02:56:38 am by bperrybap » Logged
Offline Offline
Brattain Member
View Profile
WWW
Serial read returns the ASCII value of the character sent. So if you send a 1 then number you recieve is 39, so when you do that right the cursor will move to position 39. Will you be able to see that?
Logged
Offline Offline
Edison Member
View Profile
Quote
turn on the cursor and then go to the spot you want.
Logged
Pages: [1]   Go Up
Print
Jump to:
