Loading...
Pages: [1] 2   Go Down
Author Topic: how to burn the bootloader of an arduino pro mini ?  (Read 754 times)
Offline Offline
Newbie
View Profile
Hello,
I have an arduini pro mini 3.3V 8Mhz and I need to burn its bootloader.
For that I have at my disposal  an Arduino Uno and/or a USB Serial Light Adapter http://arduino.cc/en/Main/USBSerial
I tried this guide: http://arduino.cc/en/Tutorial/ArduinoISP but it gives me avrdude: stk500_getsync(): not in sync: resp=0xfe
So I'm stuck here and I don't know how to use the usb serial light adapter to burn the bootloader.
Can you please help me?
Logged
Offline Offline
Full Member
View Profile
Try to use this tutorial as a guide:
http://pdp11.byethost12.com/AVR/ArduinoAsProgrammer.htm
You can burn a bootloader or any other hex code. It simply does not matter.
You have to connect the two boards, programmer and target, like this:
Arduino Uno programmer ---->---- target Arduino pro mini 3.3V
SS -->-- RESET
MOSI -->-- MOSI
MISO -->-- MISO
SCK -->-- SCK
You also need a 5V <---> 3.3V convertor on the four ISP lines between your 5V Arduino Uno programmer and your 3.3 V target Arduino Pro Mini.
« Last Edit: December 08, 2012, 09:17:19 pm by simplex » Logged
Offline Offline
Newbie
View Profile
Then perhaps it is a wiring problem.
Please look at my picture and tell me if I made the connections correctly.
Can I use the usb serial light adapter to program the bootloader?... and if yes How to do the wiring ?
Logged
Offline Offline
Newbie
View Profile
I also tried it this way:
d:\Programe\Arduino\hardware\tools\avr\bin>avrdude.exe  -P COM3 -b 4800 -c avrisp -p m328p -n
avrdude.exe: stk500_getsync(): not in sync: resp=0xfe
avrdude.exe done.  Thank you.
d:\Programe\Arduino\hardware\tools\avr\bin>avrdude.exe  -P COM3 -b 4800 -c avrisp -p m328p -n -v
avrdude.exe: Version 5.11, compiled on Sep  2 2011 at 19:38:36
             Copyright (c) 2007-2009 Joerg Wunsch
             System wide configuration file is "d:\Programe\Arduino\hardware\tools\avr\bin\avrdude.conf"
             Using Port                    : COM3
             Using Programmer              : avrisp
             Overriding Baud Rate          : 4800
Logged
Offline Offline
Newbie
View Profile
I am lost on the "resp=0xfe" error message. and I can't find any help anywhere for it.
what is the difference between  "resp=0xfe" and   "resp=0x00" ?
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
"Can I use the usb serial light adapter to program the bootloader?"   No, it does not support the SPI pins.
As you have it wired, you have 5V level signals going into a board with 3.3V power - this is bad for the input pins, having signals that are a lot higher than the supply voltage.
The promini regulator Used to be shown as http://www.micrel.com/_PDF/mic5205.pdf
on Promini V11 schematics, attached. This part works fine with no Vraw attached and the board powered from Vcc - I have a dozen of them powered this way at my fencing club.
The latest sparkfun design also shows the mic5205
http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Dev/Arduino/Boards/ProtoSnap-v14a.pdf
The arduino website is now showing an older V10 schematic, with no regulator part number.
http://arduino.cc/en/uploads/Main/Arduino-Pro-Mini-schematic.pdf
If some info were known about the regulator on your board to confirm that driving the output while not driving the input would not damage the regulator, I would instead connect the promini Vcc to 5V, so both boards are running from 5V. This would also put MISO signal from the promini to the Uno at the correct level.
I don't recognize the markings on your part tho, so I can't readily recommend that.
Best bet is to use 5V to 3.3V level shifters on the SCK, MOSI, Reset, and MISO signal going back.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
I tried to power the mini pro from both 3 V and 5V , same result.
Also my ftdi is 5V and I could program the mini pro a lot of times, without any problem.
To test if the connection was good, I uploaded the blink scheme on mini pro and the leds on both mini pro and arduino Uno were flashing... so no problem with the 5Volts in those pins.
Logged
Offline Offline
Newbie
View Profile
picture attached
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
"CGBS" where a Micrel part would  be marked  LB33 or KB33 per its datasheet.
I have a couple floating around (dead uCs that I zapped) that I can't seem to find, I can confirm with once I locate them.
The FTDI Basic connects right to the VCC pin also, bypassing the regulator. I can guess that supply path is okay then.
Another bootload option you might try then is NickGammon's:
http://www.gammon.com.au/forum/?id=11635
Logged
Offline Offline
Newbie
View Profile
I'm not sure what I should look for in that site.
It's not about pro mini and references to arduino uno are not helpful in my situation.
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
The site is about using an Arduino Uno as an ISP to load a bootloader.
Logged
Offline Offline
Newbie
View Profile
I've read it yesterday and once more today after a good nights sleep but still can't figure out something usefull from that site.
Not being able to understand what "resp=0xfe" is I don't know what is my problem and how I can solve it.
As a test I took mini-pro out of the arduino uno and the response was still the same "resp=0xfe" .
Meaning what? that the arduino Uno isn't responding to the IDE/avrdude?
Logged
Offline Offline
Newbie
View Profile
Can someone direct me to a person that has experience with bootloaders on mini-pro ?
Or should I ask my questions elsewhere ?
Logged
Switzerland
Offline Offline
Sr. Member
View Profile
Oby_One, I use ProMinis a lot and have burnt bootloaders to them many times.  For programming I power the ProMini at 5V, irrespective of whether it's a 3.3V or 5V model.  It doesn't seem to do any damage to the voltage regulator.  If ArduinoISP isn't working for you, I'd suggest trying Nick Gammon's excellent alternative sketch on the page already referenced.  I'm sure you can adapt his instructions to the ProMini pin-out.
Logged
Offline Offline
Newbie
View Profile
Please take a look at this small movie
https://www.youtube.com/watch?v=reuZlVGyCEk
Sorry about my english smiley
As for nick gammons alternative, I don't get what's different from what I do.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
