Topic: Is the GND pin required ? (Read 882 times) previous topic - next topic
invader7
Hello forum , another issue for me ! First of all I want to know if it is safe to connect external 12V power at my power jack and have the usb cable connected too. I know it automatically chooses the power supply , but is it safe/recommended ?
My main issue, the GND pin of arduino has to be connected to the (-) of my power supply as well as the rest sensors/devices ? or the external power supply (-) is enough at the jack barrel ? the power supply of arduino is the same as the power supply of sensors/devices. Its a atx power supply. Thanks !
retrolefty
Yes it's safe as designed.
The three ground shield pins, the USB negative connector pin, and the shell side of the external power connector are all electrically tied together on the arduino board, if that answers your question. Any external components or modules you wire to the arduino that require a ground should wire to one of the arduino ground pins.
Lefty
fungus
The only time it's dangerous is when you don't do that!
invader7
This means i have to wire GND pin to (-) , or it is happening automatically  when i insert the power jack as retrolefty said ? , No my wiring is as retrolefty said .
Thanks !
Grumpy_Mike
Yes like retrolefty said.
If you are not going through the jack, say to the Vin, then you have to connect is separately like fungus said.
invader7
Thank you all of you , i'll go with the jack !
