# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0fe63f5f, pid=3236, tid=332
# JRE version: 6.0_20-b02
# Java VM: Java HotSpot(TM) Client VM (16.3-b01 mixed mode windows-x86 )
# Problematic frame:
# C 0x0fe63f5f
# If you would like to submit a bug report, please visit:
http://java.sun.com/webapps/bugreport/crash.jsp# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0473e400): JavaThread "main" [_thread_in_native, id=332, stack(0x209d0000,0x20bd0000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
Registers:
EAX=0x00000000, EBX=0x404ef118, ECX=0x2edfd1a8, EDX=0x20bcd2fc
ESP=0x20bcd2d8, EBP=0x20bcd2e8, ESI=0x00000000, EDI=0x0473e400
EIP=0x0fe63f5f, EFLAGS=0x00010202
Top of Stack: (sp=0x20bcd2d8)
0x20bcd2d8: 20bcd2fc 20bcd2e4 404ef118 00000000
0x20bcd2e8: 20bcd328 3c319f47 0473e510 20bcd330
0x20bcd2f8: 17672e30 00000000 0473ea44 fffffffe
0x20bcd308: 20bcd308 404ef118 20bcd33c 404f7f38
0x20bcd318: 00000000 404ef118 00000000 20bcd338
0x20bcd328: 20bcd364 3c312f07 404f7948 3c318286
0x20bcd338: 17672e30 00000000 3e3abe40 20bcd344
0x20bcd348: 404ef087 20bcd36c 404f7f38 00000000
Instructions: (pc=0x0fe63f5f)
0x0fe63f4f: 33 f6 85 c0 7c 3a 8b 45 fc 8d 55 14 52 89 75 14
0x0fe63f5f: 8b 08 50 ff 91 a0 00 00 00 85 c0 7c 1a 8b 75 14
Stack: [0x209d0000,0x20bd0000], sp=0x20bcd2d8, free space=7f420bccc40k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x0fe63f5f
j sun.plugin2.main.server.IExplorerPlugin.getDocumentBase0(J)Ljava/lang/String;+0
j sun.plugin2.main.server.IExplorerPlugin.getDocumentBase()Ljava/lang/String;+31
j sun.plugin2.main.server.JVMInstance.startApplet(Ljava/util/Map;Lsun/plugin2/main/server/Plugin;JJZIZZ)Z+14
j sun.plugin2.main.server.JVMManager.startAppletImpl(Ljava/util/Map;Lsun/plugin2/main/server/Plugin;JJZLjava/lang/String;ZIZ)Lsun/plugin2/main/server/AppletID;+240
j sun.plugin2.main.server.JVMManager.startApplet(Ljava/util/Map;Lsun/plugin2/main/server/Plugin;JJZLjava/lang/String;)Lsun/plugin2/main/server/AppletID;+16
j sun.plugin2.main.server.JVMManager.startApplet(Ljava/util/Map;Lsun/plugin2/main/server/Plugin;JJZ)Lsun/plugin2/main/server/AppletID;+19
j sun.plugin2.main.server.IExplorerPlugin.maybeStartApplet()V+192
j sun.plugin2.main.server.IExplorerPlugin.access$200(Lsun/plugin2/main/server/IExplorerPlugin;)V+1
j sun.plugin2.main.server.IExplorerPlugin$BackgroundStarter$1.run()V+7
v ~StubRoutines::call_stub
C 0x293e049c
C 0x2946fcf1
C 0x293e051d
C 0x293e9e0f
C 0x293ecc07
C 0x0fe617a5
C 0x0fe6853b
C 0x0fe67a32
C [USER32.dll+0x162fa]
C [USER32.dll+0x16d3a]
C [USER32.dll+0x177c4]
C [USER32.dll+0x1788a]
C [IEFRAME.dll+0xf206c]
C [IEFRAME.dll+0x111dc6]
C [iertutil.dll+0x1415f0]
C [IEFRAME.dll+0x10027b]
C [kernel32.dll+0x1339a]
C [ntdll.dll+0x39ef2]
C [ntdll.dll+0x39ec5]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
--------------- P R O C E S S ---------------
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 4928K, used 1472K [0x3e310000, 0x3e860000, 0x3edb0000)
eden space 4416K, 33% used [0x3e310000, 0x3e480390, 0x3e760000)
from space 512K, 0% used [0x3e760000, 0x3e760000, 0x3e7e0000)
to space 512K, 0% used [0x3e7e0000, 0x3e7e0000, 0x3e860000)
tenured generation total 10944K, used 0K [0x3edb0000, 0x3f860000, 0x40310000)
the space 10944K, 0% used [0x3edb0000, 0x3edb0000, 0x3edb0200, 0x3f860000)
compacting perm gen total 12288K, used 3516K [0x40310000, 0x40f10000, 0x44310000)
the space 12288K, 28% used [0x40310000, 0x4067f2c8, 0x4067f400, 0x40f10000)
No shared spaces configured.
VM Arguments:
jvm_args: -Xbootclasspath/a:C:\PROGRA~2\Java\jre6\lib\deploy.jar;C:\PROGRA~2\Java\jre6\lib\javaws.jar;C:\PROGRA~2\Java\jre6\lib\plugin.jar -Xmx32m -Djava.awt.headless=true -Dkernel.background.download=false -Dkernel.download.dialog=false -XX:MaxDirectMemorySize=64m
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=C:\Program Files (x86)\Internet Explorer;;C:\Program Files (x86)\Wizvera\Delfino;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Services\IPT\;C:\Program Files (x86)\Toshiba\Bluetooth Toshiba Stack\sys\;C:\Program Files (x86)\Toshiba\Bluetooth Toshiba Stack\sys\x64\;C:\Program Files (x86)\Windows Live\Shared
USERNAME=hal
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 Build 7601 Service Pack 1
CPU:total 4 (8 cores per cpu, 2 threads per core) family 6 model 42 stepping 7, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht
Memory: 4k page, physical 6189616k(3917840k free), swap 12377380k(9780312k free)
vm_info: Java HotSpot(TM) Client VM (16.3-b01) for windows-x86 JRE (1.6.0_20-b02), built on Apr 12 2010 13:52:23 by "java_re" with MS VC++ 7.1 (VS2003)
time: Mon Dec 10 02:25:33 2012
elapsed time: 1 seconds
there was no problem until i got sudden 6 logs on my desktop at 2: 45 am and it's 5:15 am......in korea
and whenever i connect usb wire with or without my device, no power but a warning message that it's disabled so remove it,
before the message i think i can use other devices though i only tried a usb mouse.
so i reinstalled java 7, i changed the folder name arduino/java to other so as arduino use programfiles/java but can't even open it, i cleaned registry, reinstalled arduino
