Topic: Advice on hooking up the EFS-10 Humidity Sensor? (Read 2838 times) previous topic - next topic
anders2009
Hi guys,
my electronics is a little rusty and I am hoping you might be able to get me started in the right direction here.
I am trying to build a simple logger to register the relative humidity in a room at home (indoors). The problem boils down to understanding how to read the impedance of the sensor I believe.
The sensor I have is the EFS-10 Humidity Sensor from Hygrosens. I got it from conrad.de and the datasheet is available here: http://www.produktinfo.conrad.com/datenblaetter/150000-174999/156545-da-01-en-Feuchtesensor_EFS10.pdf.
I not a total rookie and have already built a couple of simple projects, reading resistive sensors, but this one is based on the impedance and I have no clue how to hook it up.
The datasheet says:
The measurement of impedance should be done with an AC current (without DC-offset). The recommended operating frequency is 1 kHz for a measuring voltage of maximum 1Veff.
Anyone who can help me understand this a little bit better?
Anders
MarkT
So conceptually this is like a thermistor - the resistance varies with the variable to measure - you would use a resistor divider with
the sensor in series with a fixed resistor.
However this device must recieve pure AC (no DC component or it'll be destroyed electrochemically).  This complicates things.
Since the device is relatively high resistance we can power it from two digital pins driven in anti-phase (one is HIGH when the other is LOW).
We switch the pins over every 0.5ms and this is then a 1kHz square wave (pure AC).  between the pins we wire the sensor and a 100k
resistor in series (so that the divider is roughly midrange at 50% humidity at 20C - most common case?).
Since the circuit is high impedance (> 10k) we then need to read the voltage at the midpoint of the divider twice (to allow time for
settling).
code would be something like:
#define  DRIVE1  ??   // the antiphase drive pins
#define  DRIVE2  ??
#define  SENSE  A0    // analog input
#define  PERIOD_US 1000  // for 1kHz, or use 10000 for 100Hz
#define  HALF_PERIOD_US (PERIOD_US/2)
unsigned long prev_time;
void setup ()
  pinMode (DRIVE1, OUTPUT) ;
  pinMode (DRIVE2, OUTPUT) ;
  prev_time = micros () ;
byte phase = 0 ;
float voltage ;
void loop ()
  .. do any other stuff here if only takes a few 100us ...
  while (micros () - prev_time < HALF_PERIOD_US)  ; wait for next 0.5ms time segment
  prev_time += 500 ;   // set up for the next loop
  digitalWrite (DRIVE1, phase == 0) ;   // antiphase drive
  digitalWrite (DRIVE2, phase != 0) ;
  int val = analogRead (SENSE) ;
  val = analogRead (SENSE) ;      // second read allows much longer for high impedance reading to settle
  if (phase == 0)
    val = 1023 - val ;  // reverse sense on alternate half cycles
  voltage = 5.0 * val / 1024 ;
  phase = 1 - phase ;
You can run the loop slower or faster, the datasheet says 100Hz upto 5kHz will work.
anders2009
Thank you very much!
This is exactly the kind of advice I was thinking about.
Some clever tricks in there for me to look closer into, like reading analog twice and just throwing away the first read.
Ideally it would have been great to be able to set some kind of interrupt and throw this routine in there. Don't like the busy loop approach, but that's more advanced I guess.
Thanks again!
Anders
MarkT
Well the only tricky bit about interrupt approach is the long time it takes to call analogRead().
By the way the multiple calls to analogRead() is only needed if other analog pins are being read from in the same
sketch - otherwise the analog input multiplexer never changes and the sample/hold capacitor is always connected to
the relevent source.
anders2009
Ok,
good point about the interrupt. Not a major issue for me. At this point I am just looking to take a reading, store it and to display it on an LCD with buttons to step back in time to see previous readings. Later on, there might be some serial sending of values to a host, but that is later, if ever.
Also, the thing with the input multiplexer was new to me. Very valuable info! Need to do some more reading and try to find a block diagram over the components. Still only had a vague idea about available timers, prescalers, interrupts and similar things (watchdog?).
Thanks again!
anders2009
Hey MarkT,
just a note to say thanks for the help!
Using you advice and the code as a starting point, I managed to put something together which works quite nice. It still has some issues at some break points where it is several % off in the reading. Haven't tracked it down yet, but I am convinced it is down to the way I round off the temperature and do look-ups to finally interpolate a value, using a table from the EFS-10 data sheet.
If you are interested, I have documented the result here, including the code. https://github.com/aweijnitz/Hygrometer
Thanks again!
Anders
