Author Topic: IR Remote library errors  (Read 1015 times)
I've just imported the IRRemote library, but am having trouble using it.  It first complains about IRremoteInt.h when compiling.
In file included from ir_remote_rgb_led.cpp:12:
C:\arduino-1.0.1\libraries\IRremote/IRremoteInt.h:87: error: 'uint8_t' does not name a type
C:\arduino-1.0.1\libraries\IRremote/IRremoteInt.h:88: error: 'uint8_t' does not name a type
C:\arduino-1.0.1\libraries\IRremote/IRremoteInt.h:89: error: 'uint8_t' does not name a type
C:\arduino-1.0.1\libraries\IRremote/IRremoteInt.h:92: error: 'uint8_t' does not name a type
Then if I comment out that library, which leaves IRremote.h I will get this complaint:
In file included from C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:13:
C:\arduino-1.0.1\libraries\IRremote\/IRremoteInt.h:87: error: 'uint8_t' does not name a type
C:\arduino-1.0.1\libraries\IRremote\/IRremoteInt.h:88: error: 'uint8_t' does not name a type
C:\arduino-1.0.1\libraries\IRremote\/IRremoteInt.h:89: error: 'uint8_t' does not name a type
C:\arduino-1.0.1\libraries\IRremote\/IRremoteInt.h:92: error: 'uint8_t' does not name a type
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp: In member function 'void IRsend::mark(int)':
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:173: error: 'delayMicroseconds' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp: In member function 'void IRsend::space(int)':
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:181: error: 'delayMicroseconds' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp: In member function 'void IRsend::enableIROut(int)':
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:200: error: 'OUTPUT' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:200: error: 'pinMode' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:201: error: 'LOW' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:201: error: 'digitalWrite' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp: In constructor 'IRrecv::IRrecv(int)':
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:217: error: 'volatile struct irparams_t' has no member named 'recvpin'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:218: error: 'volatile struct irparams_t' has no member named 'blinkflag'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp: In member function 'void IRrecv::enableIRIn()':
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:241: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:242: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:246: error: 'volatile struct irparams_t' has no member named 'recvpin'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:246: error: 'INPUT' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:246: error: 'pinMode' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp: In member function 'void IRrecv::blink13(int)':
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:252: error: 'volatile struct irparams_t' has no member named 'blinkflag'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:254: error: 'OUTPUT' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:254: error: 'pinMode' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp: In function 'void __vector_9()':
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:268: error: 'volatile struct irparams_t' has no member named 'recvpin'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:268: error: 'digitalRead' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:271: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:273: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:275: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:284: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:285: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:287: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:293: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:295: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:300: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:302: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:310: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:321: error: 'volatile struct irparams_t' has no member named 'blinkflag'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:323: error: 'B00100000' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:326: error: 'B11011111' was not declared in this scope
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp: In member function 'void IRrecv::resume()':
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:332: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:333: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp: In member function 'int IRrecv::decode(decode_results*)':
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:343: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:344: error: 'volatile struct irparams_t' has no member named 'rcvstate'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp: In member function 'long int IRrecv::decodeNEC(decode_results*)':
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:392: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:400: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp: In member function 'long int IRrecv::decodeSony(decode_results*)':
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:433: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:443: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp: In member function 'long int IRrecv::decodeRC5(decode_results*)':
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:518: error: 'volatile struct irparams_t' has no member named 'rawlen'
C:\arduino-1.0.1\libraries\IRremote\IRremote.cpp:529: error: 'volatile struct irparams_t' has no member named 'rawlen'
How do I fix these errors to use the IRremote libraries?? smiley-cry
peace*&^
Seattle, WA USA
Seattle, WA USA
Which library? What version of the IDE are you using? If it is later than 1.0, I suggest you find and install that version. It knows that missing include files are fatal. Later versions somehow think that the library will magically appear before the compiler get going.
where is the best place to download the ir remote library?  I'm using Arduino 1.0.1   smiley-sad
peace*&^
Seattle, WA USA
Seattle, WA USA
Do you usually answer a question with a question?
That's too bad.
United Kingdom
In file ir_remote_rgb_led.cpp, try putting #include "Arduino.h" before your #include of the IR library.
That's too bad.
I believe your question had the answer in it already, which is why I don't understand you asking "which library?" when you quoted IR Remote Library.  I'm looking for the IR remote library.  Ok.. why is using Arduino 1.0.1 too bad?  What are you using and how is that better?  Thanks!
« Last Edit: December 10, 2012, 12:58:56 am by encryptor » Logged
peace*&^
Seattle, WA USA
Seattle, WA USA
The problem is with you use of the definitive article - the IR Remote library - as if there was only one. There may be only one widely used one. There may only be one that actually works. But, I'm quite certain that there is not only one.
You said you downloaded the library, and I asked which one. The simplest thing for you to have done was posted a link, not argue about.
I have 0022, 1.0.0, 1.0.1, and 1.0.2 installed. I use 1.0.1 most of the time, because I haven't investigated what improvements were made in 1.0.2. I already explained what issues were introduced in 1.0.1, and why you should also have a copy of 1.0.0 installed.
I've added the IR Library from another source - https://github.com/shirriff/Arduino-IRremote . Plus I added #include "Arduino.h" as suggested.  Now I'm getting this error:
IRremote\IRremote.cpp.o: In function `MATCH(int, int)':
/IRremoteInt.h:176: multiple definition of `MATCH(int, int)'
ir_remote_rgb_led.cpp.o:C:\arduino-1.0.1\libraries\IRremote/IRremoteInt.h:176: first defined here
IRremote\IRremote.cpp.o: In function `MATCH_MARK(int, int)':
/IRremoteInt.h:177: multiple definition of `MATCH_MARK(int, int)'
ir_remote_rgb_led.cpp.o:C:\arduino-1.0.1\libraries\IRremote/IRremoteInt.h:177: first defined here
IRremote\IRremote.cpp.o: In function `MATCH_SPACE(int, int)':
/IRremoteInt.h:178: multiple definition of `MATCH_SPACE(int, int)'
ir_remote_rgb_led.cpp.o:C:\arduino-1.0.1\libraries\IRremote/IRremoteInt.h:178: first defined here
peace*&^
Seattle, WA USA
Seattle, WA USA
Added it where?
User downloaded libraries do NOT go in the core library folder.
What sketch are you trying to compile?
United Kingdom
Your sketch appears to be including two different versions of IRremoteInt.h, one from your sketch and one from the IRremote.cpp library file. When you downloaded the IR library from a different source, I think you didn't remove the old one completely.
I added Arduino.h at the top of my sketch where I have the IRremote include statements.  I don't think I have another location for user downloaded libraries.  C:\Users\encryptor\Documents\Arduino just has all my sketches.  Should there be a library folder there?  Attached is the code.
Added it where?
peace*&^
Seattle, WA USA
Seattle, WA USA
A libraries folder, yes.
Seattle, WA USA
Seattle, WA USA
Remove the Arduino.h include, and the IRRemoteInt.h include. They get included in other ways. Your including the IRRemoteInt.h file is what is causing the duplicate define messages.
I got the IR receiver picking up low frequencies from my Sony RM-EZ4 remote.  I see the Sony TV code 8201 gives me decimal readings in the Serial monitor.  I see the Sony Cable box code 3101 gives me Hex readings.  I want to control the color by button pressed.  Can I program specific color to remote buttons?  Which Sony protocol should I use?  Does it matter much between TV and cable box?
peace*&^
