Loading...
Pages: [1] 2   Go Down
Author Topic: Turn on lights  (Read 749 times)
Offline Offline
Newbie
View Profile
I'd like to make an ultrasonic switch for my light bulbs. Since the ground wire passes through the switch, how would I use an ultrasonic sensor or something like that to make it work? And would it need coding or a arduino?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
What does this mean? Are you trying to get the lights to come on when you get close to them?
Quote
What switch does the ground wire pass through? Usually, the switch makes/breaks the hot wire, not the ground wire.
Quote
Yes.
Logged
Offline Offline
Newbie
View Profile
Quote
Quote
Quote
Yes.
Like attaching the sensor to the wall and when I slide my hand it turns on, and when I slide my and again it turns off.
Sorry, got my electrical wiring knowledge a little mixed up.
What kind of arduino I need and others components?
Logged
California
Online Online
Edison Member
View Profile
Quote
Any kind of Arduino, a sensor and something to switch the light like a relay.
Logged
Queens, New York
Offline Offline
Edison Member
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
View Profile
You can try a close proximity setup, with either a IR distance sensor or ultrasonic sensor, just set the range from 1 inch to 3 inch, and latch the lights on when one pass is made and off when you pass again.
I don't know of any codes that will do this off hand but look for a sample button latch code, and adapt that to latch from the sensor.
If you have any code, please post it.
Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Offline Offline
Newbie
View Profile
I'm still working into making the project a reality, so I didn't start to write code yet.
Logged
Queens, New York
Offline Offline
Edison Member
View Profile
ok. do you have any parts already, the arduino, the sensor, some LEDs... anything?
Could you post a link of your exact sensor, that way we can see what you have.
Logged
Offline Offline
Newbie
View Profile
I'm thinking about using a arduino mini, and I don't know yet what kind of sensor and I would like some advice.
Logged
Queens, New York
Offline Offline
Edison Member
View Profile
ARD mini is fine, but look at the specs, I think one is 5 volts and the other is 3.3 volts. Most sensors use +5 volts, so make sure you know what  your getting.
The ultrasonic sensor look like it has 2 miniture cans on the front, and may protrude outwards. If you want something that be hidden easily, then go with the IR distance sensor. Both should work with the same code.
Logged
Offline Offline
Newbie
View Profile
What ultrasonic sensor would you recommend?
Logged
Queens, New York
Offline Offline
Edison Member
View Profile
Parallax
Logged
Offline Offline
Newbie
View Profile
I believe one of these three sensors would work out. Wich one is the best? I chose the PING))) Ultrasonic Sensor, the PIR Sensor and the Si1143 Proximity Sensor. All of them from Parallax.
Logged
Queens, New York
Offline Offline
Edison Member
View Profile
You can do multiple hand gestures and program the lights to do different things. It is much more expensive, but it all depends on what you are going to use it for. If you just want to turn the lights on and off then you can go with one of the others, but if you want to spice it up a little then go with that one.
Im not sure if the proximity sensor has its own code, because I know that the other two will work with the same code.
Logged
Offline Offline
Newbie
View Profile
Would a ARD micro work? And how to connect it to the lights? And power?
Logged
Offline Offline
Newbie
View Profile
Would the proximity sensor work with a grill in front of it? For design reasons. And could it be painted?  I want this to be an definitive solution.
« Last Edit: December 12, 2012, 05:05:50 pm by Lvothe » Logged
Pages: [1] 2   Go Up
Print
Jump to:
