Topic: Remote control flashing lights (Read 1 time) previous topic - next topic
simon72post
Hi
I have just started to learn how to program arduino and am a little confused and could do with some help.
I am trying to make some led lights start flashing randomly. which is working fine using the code bellow.
But now I would like to switch them on and off using bluetooth from my phone.
I have the bluetooth working using the other code bellow and I am able to switch a single led on and off no problem.
But I'm not sure how I would get the bluetooth program to start and stop the void loop part of the led program.
so that I can start the leds flashing by typing A and turn the leds off when I type a
Please can someone help.
bluetooth code
Code: [Select]
simple LED test
char val;         // variable to receive data from the serial port
int ledpin = 2;  // LED connected to pin 2 (on-board LED)
  pinMode(ledpin = 2, OUTPUT); // pin 2 (on-board LED) as OUTPUT
    Serial.begin(115200);       // start serial communication at 115200bps
  if( Serial.available() )       // if data is available to read
  val = Serial.read();         // read it and store it in 'val'
  if( val == 'a' )               // if 'a' was received led 2 is switched off
    digitalWrite(ledpin, LOW);    // turn Off pin 2 off
  if( val == 'A' )               // if 'A' was received led 2 on
    digitalWrite(ledpin = 2, HIGH);  // turn ON pin 2 on
Flashing led code
Code: [Select]
int timer = 30;           // The higher the number, the slower the timing.
int ledPins[] = {
  12, 9, 2, 7, 10, 4, 6, 13, 5, 11, 8, 3 };       // an array of pin numbers to which LEDs are attached
int pinCount = 12;           // the number of pins (i.e. the length of the array)
  int thisPin;
  // the array elements are numbered from 0 to (pinCount - 1).
  // use a for loop to initialize each pin as an output:
  for (int thisPin = 0; thisPin < pinCount; thisPin++)  {
    pinMode(ledPins[thisPin], OUTPUT);
  // loop from the lowest pin to the highest:
    // turn the pin on:
    digitalWrite(ledPins[thisPin], HIGH);
    delay(timer);
    // turn the pin off:
    digitalWrite(ledPins[thisPin], LOW);
  // loop from the highest pin to the lowest:
  for (int thisPin = pinCount - 1; thisPin >= 0; thisPin--) {
    // turn the pin on:
    delay(timer);
Thanks
PaulS
Your loop() function (not your void loop() function) does something. You want it to do something only when it receives some character. It really doesn't seem that difficult, especially since you managed to accomplish that feat once.
You try something, and if it doesn't work, let is know what you tried, and what the results were.
simon72post
Hi
Thanks for you response.
I have spent a bit more time on the code but am still getting some error messages.
Quote
remote_Random_Fairy_lights.cpp: In function 'void setup()':
remote_Random_Fairy_lights.cpp:26:2: error: expected initializer before 'if'
I keeping looking through the program but am unable to spot the problems.
here is a copy of the program.
Code: [Select]
int ledPins[] = {
  int thisPin;
pinMode(thisPin = 0, OUTPUT); // pin 2 (on-board LED) as OUTPUT
     if( val == 'A' )               // if 'A' was received  // turn the pin on:
    digitalWrite(thisPin = 0, HIGH);
    delay(timer);
   if( val == 'a' )               // if 'a' was received // turn the pin off:
   digitalWrite(thisPin, LOW);
Please could I have some advice on where the problem is.
Thanks
dannable
Check your curly brackets? Especially within the loop section.
Beginners guide to using the Seeedstudio SIM900 GPRS/GSM Shield
UKHeliBob
Before any code in a function there needs to be a {
Code: [Select]
Check your { and } pairs carefully.  You have the loop() function inside the setup() function
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
PaulS
Code: [Select]
You don't ever want that for loop to end, do you? Why are you assigning a value to thisPin in this function call?
Code: [Select]
  int thisPin;
The variable thisPin used in the for loop is not the same variable that will be in scope when the for loop ends. What is the other uninitialized thisPin for?
Where does your for loop end? Why is loop() defined in setup(), inside the for loop?
simon72post
Hi
Just want to say thanks and let you know I got it working.
Here is a copy of the code.
Code: [Select]
int ledPins[] = {
    int thisPin;
  //pinMode(thisPin = 0, OUTPUT); // pin (on-board LED) as OUTPUT
    // turn the pin on:
    delay(timer);
