Topic: Kriege den SPI Bus nicht zum laufen (Read 6450 times) previous topic - next topic
R1der
Hallo Leute,
Nutze ein Arduino Mega 2560 und ein 1,8" LCD von SainSmart.
Folgender Code wird genutzt, läuft aber nicht:
Code: [Select]
// Pins SCLK and MOSI are fixed in hardware, and pin 10 (or 53)
// must be an output
//#define sclk 13    // for MEGAs use pin 52
//#define mosi 11    // for MEGAs use pin 51
#define cs 10   // for MEGAs you probably want this to be pin 53
#define dc 9
#define rst 8  // you can also connect this to the Arduino reset
// Color definitions
#define BLACK           0x0000
#define BLUE            0x001F
#define RED             0xF800
#define GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
#include <ST7735.h>
#include <SPI.h>
// Option 1: use any pins but a little slower
//ST7735 tft = ST7735(cs, dc, mosi, sclk, rst);
// Option 2: must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
ST7735 tft = ST7735(cs, dc, rst);
void fillpixelbypixel(uint16_t color) {
 for (uint8_t x=0; x < tft.width; x++) {
   for (uint8_t y=0; y < tft.height; y++) {
     tft.drawPixel(x, y, color);
 delay(100);
void setup(void) {
 Serial.print("hello!");
 tft.initR();               // initialize a ST7735R chip
 Serial.println("init");
 tft.writecommand(ST7735_DISPON);
 uint16_t time = millis();
 tft.fillScreen(BLACK);
 time = millis() - time;
 Serial.println(time, DEC);
 testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", WHITE);
 delay(10000);
 //a single pixel
 tft.drawPixel(tft.width/2, tft.height/2, GREEN);
 // line draw test
 testlines(YELLOW);
 // optimized lines
 testfastlines(RED, BLUE);
 testdrawrects(GREEN);
 testfillrects(YELLOW, MAGENTA);
 testfillcircles(10, BLUE);
 testdrawcircles(10, WHITE);
 Serial.println("done");
 tft.writecommand(ST7735_INVON);
 tft.writecommand(ST7735_INVOFF);
void testlines(uint16_t color) {
  for (uint16_t x=0; x < tft.width; x+=6) {
    tft.drawLine(0, 0, x, tft.height-1, color);
  for (uint16_t y=0; y < tft.height; y+=6) {
    tft.drawLine(0, 0, tft.width-1, y, color);
    tft.drawLine(tft.width-1, 0, x, tft.height-1, color);
    tft.drawLine(tft.width-1, 0, 0, y, color);
    tft.drawLine(0, tft.height-1, x, 0, color);
    tft.drawLine(0, tft.height-1, tft.width-1, y, color);
    tft.drawLine(tft.width-1, tft.height-1, x, 0, color);
    tft.drawLine(tft.width-1, tft.height-1, 0, y, color);
void testdrawtext(char *text, uint16_t color) {
 tft.drawString(0, 0, text, color);
void testfastlines(uint16_t color1, uint16_t color2) {
  for (uint16_t y=0; y < tft.height; y+=5) {
    tft.drawHorizontalLine(0, y, tft.width, color1);
  for (uint16_t x=0; x < tft.width; x+=5) {
    tft.drawVerticalLine(x, 0, tft.height, color2);
void testdrawrects(uint16_t color) {
  tft.drawRect(tft.width/2 -x/2, tft.height/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
for (uint16_t x=tft.width-1; x > 6; x-=6) {
  tft.fillRect(tft.width/2 -x/2, tft.height/2 -x/2 , x, x, color1);
  tft.drawRect(tft.width/2 -x/2, tft.height/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
 for (uint8_t x=radius; x < tft.width; x+=radius*2) {
   for (uint8_t y=radius; y < tft.height; y+=radius*2) {
     tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
 for (uint8_t x=0; x < tft.width+radius; x+=radius*2) {
   for (uint8_t y=0; y < tft.height+radius; y+=radius*2) {
     tft.drawCircle(x, y, radius, color);
Ist ein Example vom Hersteller... Alles nach angaben aufgelegt.
R1der
Nutze ich den "langsamen" Code, funktionier alles:
Code: [Select]
// You can use any (4 or) 5 pins
#define sclk 4
#define mosi 5
#define cs 6
#define dc 7
#define BLUE            0x001F
#define RED             0xF800
#define CYAN            0x07FF
#include <ST7735.h>
#include <SPI.h>
//ST7735 tft = ST7735(cs, dc, rst);
 delay(100);
void setup(void) {
 //a single pixel
 // line draw test
 testlines(YELLOW);
 // optimized lines
Habe noch so gut wie keine Erfahrung. Mein Ziel ist eine Grafikanzeige und will halt die SD-Karte nutzen wie in folgendem Code und drehe mich halt im Kreis...
Vllt. kann mir ja jemand helfen?!
R1der
#2
Dec 10, 2012, 12:09 am Last Edit: Dec 10, 2012, 08:43 am by R1der Reason: 1
Code: [Select]
#include <ST7735.h>
#include <SD.h>
#include <SPI.h>
// If we are using the hardware SPI interface, these are the pins (for future ref)
#define sclk 13
#define mosi 11
// You can also just connect the reset pin to +5V (we do a software reset)
#define rst 8
// these pins are required
#define cs 10
#define dc 9
#define BLUE            0x001F
#define RED             0xF800
#define CYAN            0x07FF
// to draw images from the SD card, we will share the hardware SPI interface
// For Arduino Uno/Duemilanove, etc
//  connect the SD card with MOSI going to pin 11, MISO going to pin 12 and SCK going to pin 13 (standard)
//  Then pin 4 goes to CS (or whatever you have set up)
#define SD_CS 4    // Set the chip select line to whatever you use (4 doesnt conflict with the library)
// the file itself
File bmpFile;
// information we extract about the bitmap file
int bmpWidth, bmpHeight;
uint8_t bmpDepth, bmpImageoffset;
void setup(void) {
 pinMode(cs, OUTPUT);
 digitalWrite(cs, HIGH);
 // initialize a ST7735R TFT
 tft.initR();      // change this to initB() for ST7735B TFT's
 // Just do a simple test
 Serial.print("Initializing SD card...");
 if (!SD.begin(SD_CS)) {
   Serial.println("failed!");
   return;
 Serial.println("SD OK!");
 bmpFile = SD.open("parrot.bmp");
 if (! bmpFile) {
   Serial.println("didnt find image");
   while (1);
 if (! bmpReadHeader(bmpFile)) {
    Serial.println("bad bmp");
    return;
 Serial.print("image size ");
 Serial.print(bmpWidth, DEC);
 Serial.print(", ");
 Serial.println(bmpHeight, DEC);
 bmpdraw(bmpFile, 0, 0);
// This procedure reads a bitmap and draws it to the screen
// its sped up by reading many pixels worth of data at a time
// instead of just one pixel at a time. increading the buffer takes
// more RAM but makes the drawing a little faster. 20 pixels' worth
// is probably a good place
#define BUFFPIXEL 20
void bmpdraw(File f, int x, int y) {
 bmpFile.seek(bmpImageoffset);
 uint32_t time = millis();
 uint16_t p;
 uint8_t g, b;
 int i, j;
 uint8_t sdbuffer[2 * BUFFPIXEL];  // 3 * pixels to buffer
 uint8_t buffidx = 2*BUFFPIXEL;
 //Serial.print("rotation = "); Serial.println(tft.getRotation(), DEC);
 //set up the 'display window'
 tft.setAddrWindow(x, y, x+bmpWidth-1, y+bmpHeight-1);
 uint8_t rotback = tft.getRotation();
 //tft.setRotation();
 for (i=0; i< bmpHeight; i++) {
   // bitmaps are stored with the BOTTOM line first so we have to move 'up'
   for (j=0; j<bmpWidth; j++) {
     // read more pixels
     //if (buffidx >= 2*BUFFPIXEL) {
       //bmpFile.read(sdbuffer, 3*BUFFPIXEL);
       //buffidx = 0;
       sdbuffer[0] = bmpFile.read();
       sdbuffer[1] = bmpFile.read();
       sdbuffer[2] = bmpFile.read();
       //Serial.print(sdbuffer[0], HEX);
       //Serial.print(sdbuffer[1], HEX);
       //Serial.print(sdbuffer[2], HEX);
     //p = (sdbuffer[1] << 8) | sdbuffer[0];
     //buffidx++;
     //buffidx++;
     // convert pixel from 565 to 888
     //b = sdbuffer[0] & 0x1f;
     //g = (sdbuffer[0] >> 5) | (sdbuffer[1] << 5);
     //r = sdbuffer[1] >> 3;
     // convert pixel from 888 to 565
     b = sdbuffer[0];     // blue
     g = sdbuffer[1];     // green
     p = sdbuffer[2];     // red
     p >>= 3;
     p <<= 6;
     g >>= 2;
     p |= g;
     p <<= 5;
     b >>= 3;
     p |= b;
    //Serial.print(p, HEX);
     // write out the 16 bits of color
     //tft.drawPixel(i, j, p);
     tft.pushColor(p);
 Serial.print(millis() - time, DEC);
 Serial.println(" ms");
boolean bmpReadHeader(File f) {
  // read header
 uint32_t tmp;
 if (read16(f) != 0x4D42) {
   // magic bytes missing
   return false;
 // read file size
 tmp = read32(f);
 Serial.print("size 0x"); Serial.println(tmp, HEX);
 // read and ignore creator bytes
 read32(f);
 bmpImageoffset = read32(f);
 Serial.print("offset "); Serial.println(bmpImageoffset, DEC);
 // read DIB header
 tmp = read32(f);
 Serial.print("header size "); Serial.println(tmp, DEC);
 bmpWidth = read32(f);
 bmpHeight = read32(f);
 if (read16(f) != 1)
   return false;
 bmpDepth = read16(f);
 Serial.print("bitdepth "); Serial.println(bmpDepth, DEC);
 if (read32(f) != 0) {
   // compression not supported!
   return false;
 Serial.print("compression "); Serial.println(tmp, DEC);
 return true;
// These read data from the SD card file and convert them to big endian
// (the data is stored in little endian format!)
// LITTLE ENDIAN!
uint16_t read16(File f) {
 uint16_t d;
 uint8_t b;
 b = f.read();
 d = f.read();
 d <<= 8;
 d |= b;
 return d;
// LITTLE ENDIAN!
uint32_t read32(File f) {
 uint32_t d;
 uint16_t b;
 b = read16(f);
 d = read16(f);
 d <<= 16;
 d |= b;
 return d;
Bekomme im Serial Monitor immer
Quote
Initializing SD card...failed!
-Holger-
Servus,
Hast du das im Kommentar denn mal getestet?
Code: [Select]
PS: mit Code-Tags (#) muss man nicht 5 Seiten scrollen, wenn du deinen Code postest... :)
R1der
Das mit dem Code-Tag lief etwas schief bei meinem letzten Post.
Ja, habe das im Kommentar getestet, funktioniert dennoch nicht.
Kann es irgendwie an der SPI.h liegen, ohne dass ich es im Compiler mitkriege?
-Holger-
Hmmmm, bevor wir es auf die Bibliothek schieben, schauen wir uns nochmal das LCD an...
Welche Pins verwendet denn das LCD / das Shield?
Fest die Pins 9 bis 13?
In dem fall hast du ein Problem, da da eben kein Hardware-SPI beim Mega ist.
Oder verwendet das Shield den ICSP-Header (also der 2*3-polige Stecker)
In dem Fall bin ich dann auch erstmal ratlos.
R1der
#6
Dec 10, 2012, 09:04 am Last Edit: Dec 10, 2012, 09:12 am by R1der Reason: 1
Verbinde das LCD über Steckverbindungen, da es kein extra Shield ist und nicht dierekt gesteckt werden kann.
Bezeichnungen auf dem LCD sind wie folgt:
VCC
GND
SCL -> 13
SDA -> 11
RS/DC -> 9
RES -> 8
CS -> 10
SD-CARD:
MISO -> ???
SCLK - >???
MOSI -> ???
CS -> 4
-Holger-
Ah, okay. Ich befürchte, ich hab dein Problem nicht 100% verstanden :-)
daher ein paar Fragen, die vielleicht auch den anderen helfen:
Bestätige oder verneine mal
- SD-Karte alleine ohne LCD tut?
- LCD alleine ohne SD tut auch (in der "langsamen" Variante)? (habe ein ja gelesen)
- LCD alleine ohne SD tut auch auf Hardware-SPI?
- SD auf SPI und gleichzeitig LCD in "langsam" tut auch?
- sobald du SD und LCD zusammen auf die Hardware-SPI-Pins belegst, tut nix
R1der
Hatte bisher keinen Zugriff auf die Karte, egal was ich probiert habe.
LCD in langsame Version läuft (Hab versucht damit auch die Karte zu betreiben, geht nicht).
Nutze ich nur cs und dc tut es nichts mehr...
Für die SD-Card nutzung hab ich halt nur den Beispiel-Code von oben.
Mir gehts erst mal darum das LCD über SPI nutzen zu können.
-Holger-
Guat, dann haben wir ja erstmal nur ein Problem, das LCD.
Erstmal, wenn ich deine Pinbelegung (10-13) sehe: ist dir das klar:
Quote
SPI: 50 (MISO), 51 (MOSI), 52 (SCK), 53 (SS). These pins support SPI communication using the SPI library. The SPI pins are also broken out on the ICSP header, which is physically compatible with the Uno, Duemilanove and Diecimila.
Beim Mega sind die pins leider ansders als beim UNO.
Was passiert denn, wenn du diese Pins nimmst, das Programm auch mit 53 compilerst und nix mit SD-Karte im Programm hast?
R1der
Code: [Select]
#define dc 9
#define BLUE            0x001F
#define RED             0xF800
#define      CYAN            0x07FF
#include <ST7735.h>
#include <SPI.h>
Also im oberen Code die Pin 10 durch Pin 53 ersetzen?
Tut mir leid für diese simplen Fragen, Stecke nicht so in dem Thema drinn und bin blutiger Anfänger...
-Holger-
Genau, und Hardwareseitig wie folgt ändern:
SCL -> SCK = 52
SDA -> MOSI = 51
RS/DC -> 9
RES -> 8
CS -> SS = 53
Fragen bildet schließlich, also keine Sorge.
R1der
SCL -> SCK = 52
SDA -> MOSI = 51
RS/DC -> 9
RES -> 8
CS -> SS = 53
ok... Hab meinen Fehler gefunden denk ich...
Habe die Pins in den Kommentaren nicht genutzt, die für den MEGA notwendig sind...
R1der
Sehe gerade meinen Stand der 100% läuft:
Code: [Select]
#define sclk 4
#define mosi 5
#define cs 6
#define dc 7
#define rst 8
#define BLUE            0x001F
#define RED             0xF800
#define CYAN            0x07FF
#include <ST7735.h>
#include <SPI.h>
d.h. das funktioniert also auch auf anderen Pins...
die highspeed-methode läuft nicht.
dafür werden nur cs, dc und rst verwendet:
Code: [Select]
würde ja wie folgt aussehen:
Code: [Select]
//#define sclk 4
//#define mosi 5
#define cs 53
#define dc 7
#define rst 8
Funktioniert dennoch nicht
-Holger-
#14
Dec 10, 2012, 12:28 pm Last Edit: Dec 10, 2012, 12:33 pm by -Holger- Reason: 1
Schade,
Leider wäre ich jetzt auch am Punkt, wo ich hier nachfragen müsste...  8)
Vielleicht hat ja einer der "alten Hasen" hier (sorry Jungs, nicht persönlich  ]:D ) noch nen Tip geben oder hat deine Library (die ich persönlich nicht kenne) selber am laufen.
Edit: nicht, dass wir aneinander vorbeireden: ja, der Konstruktor hat weniger Parameter, aber das heisst nicht, dass du weniger Kabel brauchst. Bei Hardware-SPI sind die nicht übergebenen Pins nur fest definiert...
