Topic: Solution for the 5V vs 3.3V problem (Read 34651 times) previous topic - next topic
graynomad
Quote
I don't think I can use these
Probably not, I can't see that they are linear.
Quote
I'm not sure if I should just use a voltage divider because I'm concerned with accuracy to a certain degree.
A voltage divider is the easiest and probably the best way to do this. I see no reason to think there would be accuracy problems if you use good resistors.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
bobcousins
Just for interest, here is a board I am working on to interface Due to a 3D printer controller (RAMPS)
http://reprap.org/wiki/File:RAMPS-RIB-Back.jpg
http://reprap.org/wiki/File:RAMPS-RIB-Assembly.jpg
It is application specific, I am using TXS0108 to adapt some signals, with some gate drivers for MOSFETS.
I had trouble finding connectors with the same height, but they seem to connect ok.
Source files on github https://github.com/bobc/bobc_hardware/tree/master/RAMPS-FD
Please ask questions in the forum so everyone can benefit. PM me for paid work.
graynomad
Thanks for that Bob, looks interesting.
FWIW I think I've found a way to do this with very good compatibility for all/most shields.
BTW, nice Due pinout diagram you have there :)
______
Rob
JChrispy58
Looks like i'm using a voltage divider....Thanks Rob for your help.
Louis90
Hello, read through those comments and is amaze with it. But i still got doubt. Please help me. Im so wan the 12 bit PWM provided by the I/O pins from this arduino due. But my concern are:
1. whether those logic level converter IC  can work this 12 bits PWM? because im doing with hall sensor geared motor, worry that the accuracy will be affected.
2. is those bi-directional converter? means if i attach all the digital pins to the converter, can i read/write data as other arduino board?
3. can those work with analog pins?
muqthyar
Guys please check the level translator from below link
http://www.tenettech.com/product/3263/bi-directional-logic-level-converter
zhivkec
#36
Sep 19, 2015, 10:15 pm Last Edit: Sep 19, 2015, 10:33 pm by zhivkec
I find this shield very usable. I would like to use it as interface for drivers of stepper drivers. These drivers require 5V, and arduino due can output only 3.3V.
So where is this "way to do this with very good compatibility for all/most shields"?
Schematic? Pcb ?
Can this shield be bought somewhere already? It's old post...
OK I found this guy: https://digistump.com/wiki/digix/tutorials/levelshifter
http://digistump.com/products/51
I see it costs 14$ in USA, but i'm from Europe, can somebody suggest me similar shield and to be able to buy it here in old continent :) ?
regards,
______
Rob
graynomad
Sorry zhivkec but that was 2.5 years ago, I have no idea what I was referring to at the time.
I do remember having a complicated design that required MUXes and analogue switches, but this is pre history to me these days.
