Topic: State Machines (Read 2343 times) previous topic - next topic
danieljay
So I am trying to put together a state machine, and am running into some difficultly.
I have formatted my program like so:
public enum states { STATE_1, STATE_2, STATE_3, STATE_4, STATE_5, STATE_6, MAX_STATES };
states state = new states;
switch (state){
case STATE_1 :
// if this does that, do something
state = STATE_2;
break;
case STATE_2:
state = STATE_3;
break;
//etc etc
but I am receiving an error saying "cannot find anything named "state". What am I missing?
Cheers!
nickgammon
This compiles:
states state;
void setup ()
  }  // end of setup
void loop ()
  switch (state)
    case STATE_1 :
      state = STATE_2;
      break;
    case STATE_2:
      state = STATE_3;
      break;
    }  // end of switch
  }  // end of loop
More info:
danieljay
EEk well I feel ridiculous. This question was actually intended for the Processing forum. I posted it there, but the problem lies in implementing this in Processing.
PaulS
Well, now, it's quite clear what each of those states means. Not.
danieljay
Hey PaulS,
I was going to transition to each case depending on specific arguments. What exactly do you mean by,
Was just curious.
nickgammon
I imagine PaulS means to name the states in a meaningful way, like:
BUTTON_PRESSED, DOOR_OPENED, BUTTON_RELEASED, DOOR_CLOSED, GOAT_ESCAPED
That sort of thing. Calling them STATE_1, STATE_2 etc. is a bit like calling variables: variable1, variable2, etc. which is pretty useless.
More info:
danieljay
Thanks for the clarification, guys.
GoForSmoke
All a state machine is is a loop that has some/all parts that run on the value of a variable.
The rest is in how you do it though keep in mind that any task has a least amount of work to accomplish, it's funny how many people not-think/supposed-to a whole lot of extra steps to do the same job.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
johncc
Sorry, this doesn't compile:
post 136723.msg1078711: syntax error at " people not-think/supposed-to a whole lot of extra steps"
Please post the code that you're actually using to make this point  :smiley-roll:
GoForSmoke
Not-thinking is for example what you just did.
Supposed-to is like how I'm supposed to hand you code.
You don't have to use switch-case in a state machine nor does state have to be limited to a single action. I'm not being much more specific than your original post which is very general, just giving you tips. Your tip-compiler seems to be turned off or powered down.
You want to find code examples, Google arduino state machine. Maybe add nick gammon to the search words, he's gifted at making explanations.
