Loading...
Pages: [1]   Go Down
Author Topic: domotics concept  (Read 338 times)
Belgium
Offline Offline
Newbie
View Profile
Hello everyone
i want some advice
I want to make a domotics system with I2C (mainly attiny45 with software-library-i2c IF POSSIBLE), and i want to be able to control it by buttons and software. This includes computer(mac + windows)  and android smartphone. I could make an android, windows and mac program or i could make a internet site... what do you guys sugest. Also what programming languages would i have to learn? (labview is also an option). The moment i pres a button (hardware or software) i want near real time response of the attinys if possible.
I am willing to learn new languages if neccesary.
the goal is to make a graphical layout (like the attachment below)
i dont really want to use an arduino with ethernet. I prefer a computer as server. or even a raspberryPi
Now i want you guys to say what is the best/easiest/... software(s) to do it
please give advice or say if it is possible for a guy aged 17 and a half
please note: i have litle programming skills, but i really understand a program when i see it, and if necesary i want to learn them better
thank you
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
The internet site has the advantage that I could turn your lights on while you are sleeping. No, wait, I mean that you could turn your lights on and off from any device that incorporates a web browser. No need to write a new program every time you get a new device.
Quote
C++ and a little about html forms. Certainly a knowledge of client/server architecture, and what that implies, would be useful.
Quote
You have labview on your phone?
Quote
I'm not sure how you would connect an ethernet shield to an attiny. Even if you could, instantaneous reaction is an unrealistic expectation. It takes time to convert the data to a usable message on the PC/phone side, to transmit that message to the ethernet shield, to get that message to the Arduino/ATTiny, to decipher that message, and to implement the instruction(s) contained in that message. We're not talking minutes, here, but we are not talking instantaneous, either.
Quote
You want the PC to act like a raspberry pi?
With the PC as the server (or the raspberry pi, in case it was just a word order mismatch), you still need some way to get the user-intent to the Arduinos/ATTinys. How is that to happen?
Quote
To do what parts? There are parts that involve HTML. There are parts that involve getting data from the server to the MCUs. There are parts that involve using that data on the MCUs.
Quote
No, I think you need to be at least 17 and three quarters.
Of course it is possible. Age has little to do with willingness to learn and experiment.
Quote
By the time you get done, this will no longer be true.
Quote
It definitely will be.
Logged
the land of sun+snow
Offline Offline
Edison Member
View Profile
WWW
As this is an Arduino forum, people will naturally suggest using Arduino, and it's native
language is C [C++ if you want to be more exact].
The major problem with your idea is you have sensors all over the house, which means
running bundles of wires every which way. That will rapidly become a big hassle, and also
make an unsightly mess. Also, I2C typically uses 5V signals [sometimes 3.3V], and the I2C
buss is not made for use with wires more than a couple of feet long, at most. You will
probably need to consider another communications hardware scheme.
Some people use RF [eg, XBee] which will end up costing a fair amount for such a distributed
system as shown. Some people use RS485/RS422, or CAN buss.
All in all, what you should probably do is think about having a separate processor in every room,
to control and sense locally, and then think about a scheme for communicating between the
various processors. This all will cost maybe $200-400 for your system [maybe].
Also, check out this board, http://arduino.cc/forum/index.php/board,16.0.html
Logged
Kitchen-Sink Arduino-compatible boards
Belgium
Offline Offline
Newbie
View Profile
Quote
I have labview on pc (labview only exists computers and for windows phone)
i was thinking of making a server with labview that makes a webpage or server list or so (i dont even know if this is possible  smiley-razz ) but labview can connect trough usb with the main arduino.
Quote
Quote
i first was thinking about making multiple attinys with I2C/twi and letting them talk to 1 arduino uno connected with usb to a computer OR letting the attinys talk trough i2c/TWI to a raspberryPi (the raspberry pi should be configurable as a webserver)
there are also these chips that are called I2C extenders for about 2.50 euro each. link: http://www.nxp.com/documents/data_sheet/P82B715.pdf and http://be02.rs-online.com/web/p/i-o-expanders/0821784/
About the speed: maybe i could lower the i2c to 40 Hz or even less for less interference with any magnetic field things (couldnt get the right word)
SO, one arduino in each room and connecting them with I2C extenders???
btw thanks for the reply guys smiley
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
Man I wish I was young enough that half a year mattered smiley
Quote
That's reasonable, certainly I'd go with a decent amount of smarts in each room to keep local decisions independent of the rest of the system, that way when your Pi blows up at least you can still turn the lights on in each room.
The PCA9600 uses balanced lines so should have similar abilities to RS-485 although I haven't used it.
_____
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Edison Member
View Profile
WWW
You seem to have the idea down about using a distributed processing scheme.
Those I2C extenders look like they'll do the job.
Logged
Belgium
Offline Offline
Newbie
View Profile
wich extenders? the PCA9600 or the P82B715?
if answer is pca9600, can i also connect multiple devices at the long cable side and/or the short cable side?
« Last Edit: December 10, 2012, 09:45:02 am by darkspeedy26 » Logged
Offline Offline
Tesla Member
View Profile
WWW
Yes you can multidrop with the PCA9600 but I'm pretty sure the P82B715 is just point to point.
And as I mentioned the PCA9600 uses balanced lines and that's always a plus for noise.
_____
Rob
Logged
Belgium
Offline Offline
Newbie
View Profile
thanks for the help guys smiley
Logged
California
Offline Offline
Edison Member
View Profile
I'd recommend using wireless unless you are working with a house still in construction or have a good amount of experience running wires through houses. Wireless doesn't have to be expensive, just look at the JeeNode as an example.
Logged
Offline Offline
Edison Member
View Profile
WWW
I was referring to the I2C extender datasheet where it said 50m.
Be careful with the JeeNode. I bought a couple, and they have a tiny tiny, maybe 6-mil
wide, trace hidden by solder mask that connects the FTDI adaptor power to the board.
It's too small to see, and certainly silly for a "power" jumper.
So, if you connect your battery power to the JeeNode, and then try to communicate with it
by plugging in the FTDI adaptor, you can blow the USB port on your PC.
Logged
Pages: [1]   Go Up
Print
Jump to:
