Loading...
Pages: [1]   Go Down
Author Topic: Is it possible to run a nano at 3.3V?  (Read 189 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
I guess the subject says it all.  According to the datasheet, the mega328 can run off of voltages from 1.8 - 5.5V.  I know that Vin goes to the voltage regulator but the 5V pin I believe goes straight to the mega328 so can I just put 3.3v on that pin and run the whole nano at 3.3v?
Logged
Arduino Uno;
Mega328
Offline Offline
Sr. Member
View Profile
I've run a 328P at 16 mhz (with a crystal, not a resonator) at 3 volts (two AA cells in series). Worked just fine.
Why not just try it? Keep testing lower and lower voltages until the board stops working. Then you will know what you can and cannot do.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Indeed - but remember 16MHz at 3.3V is out of spec, I think its only actually guaranteed to work upto about 12MHz, but
that is across the full temperature range (so keep it cool, not too difficult).  CMOS clocks faster at lower temperatures and
higher supply voltages
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Thanks guys!
Logged
Arduino Uno;
Mega328
Pages: [1]   Go Up
Print
Jump to:
