Topic: Using Servo variable as a member variable of my new Servo lib doesn't work (Read 797 times) previous topic - next topic
SteveChang
Hi all,
I want to write a new Servo Class for my project. It needs to wrap the Servo Class provided by Arduino library.  It doesn't work, as there's no driving signal output. Here's my code.
I'd be appreciate if you can give a hand. ( I use Duemilanove 328,  Arduino 1.0.2 IDE, on Win7)
My_ServoDriver_test.h
class My_ServoDriver_test
public:
My_ServoDriver_test();
My_ServoDriver_test(int portNum);
//pos: 0 -180
void setServoPosition(int pos);
public:
Servo servo;
My_ServoDriver_test.cpp
#include "My_ServoDriver_test.h"
My_ServoDriver_test::My_ServoDriver_test()
My_ServoDriver_test::My_ServoDriver_test(int portNum)
servo.attach(portNum);
void My_ServoDriver_test::setServoPosition(int pos)
servo.write(pos);
TestServoDriver.ino
#include <My_ServoDriver_test.h>
#include <Servo.h>
My_ServoDriver_test servoDriver(11);
//Serial.begin(9600);
//servoDriver.servo.attach(11);
  servoDriver.setServoPosition(0);
  servoDriver.setServoPosition(180);
If I comment the "servo.attach(portNum); " in the "My_ServoDriver_test::My_ServoDriver_test(int portNum)", and use "servoDriver.servo.attach(11);" in setup(), it works.
PaulS
Of course. When your constructor is called, the pin is not ready to have a servo attached. But, it goes through the motions.
Then, the init() method gets called, and resets all the pins, to INPUT. A servo on an INPUT pin is kind of useless, don't you think?
When you perform the attach() in setup(), the pin is set as an OUTPUT pin, which lets the servo actually receive some data.
You should NOT be performing hardware-related tasks in a constructor.
Now you know why there is a separate attach() method in the servo class.
Your class should have a begin() method that does the hardware-related stuff. That method should be called in setup().
