Topic: Controlling a stand alone LED remotely (Read 1 time) previous topic - next topic
Erika86
I'm trying to making a small installation and I would need a LED inside a glass (without any wire) that turns on when I raise the glass.
Is there any way to control this kind of behaviour?
Thanks
fungus
Sure, all you need is a pressure switch on the bottom of the glass.
There's going to be a more electronics inside the glass than just an LED though. Batteries, wires, a transistor or two...
dhenry
One way would be to use an inductor + the led's capacitance to form an l/c tank. If you energy the whole thing with the right frequency, the led will light up. The same principle behind those little led phone-is-ringing indicators.
fungus
That's a good idea. That way you could have the most of the electronics out of sight up your sleeve.
fungus
Another way would be to use something similar to Juan Mayoral's "Meteors" trick, as seen here:
http://www.youtube.com/watch?v=85H0-k77bS0
mrboni
fungus
What's the tech in that trick?
I'm bound by the magician's code...
Erni
A tilt switch + resistor+LED+coincell(s)
