Topic: Control flow troubles (Read 4706 times) previous topic - next topic
alkopop79
I'm building a simple EEPROM programmer that allows me to set individual bytes. The idea is to be able to enter an address on the serial monitor, then the data. I managed to cobble a sketch together which does not work properly. The sketch should take any number entered and turn it into a byte, then set 8 digital outputs (pin 2-9) with the individual bits. My only worry is that the sketch does set the first pin (pin 2) but the rest of them. I think the for loop is executed only once. What am I doing wrong?
char inData[10];
int index, i;
boolean started = false;
boolean ended = false;
int AP[8] = {
 2,3,4,5,6,7,8,9};
int AD[8] = {
 0,0,0,0,0,0,0,0};
void setup(){
 Serial.println("ready");
 for (i=0;i<8;i++) {
   pinMode(AP[i],OUTPUT);
 // Setup Data Pins
 for (i=0;i<8;i++) {
   pinMode(AD[i],OUTPUT);
 while(Serial.available() > 0)
   char aChar = Serial.read();
   if(aChar == '>')
     started = true;
     index = 0;
     inData[index] = '\0';
   else if(aChar == '<')
     ended = true;
   else if(started)
     inData[index] = aChar;
     index++;
 if(started && ended){
   int inInt = atoi(inData); // Convert the string to an integer
   for(int j=0; j<8; j++){
     int b = bitRead(inInt,j);
     Serial.println(b);
     if((b&bit(j))>0) {
       AD[j]=HIGH;
     else {
       AD[j]=LOW;
     digitalWrite(AP[j],AD[j]);
     delay(100);
   Serial.println(" ");
   // Get ready for the next time
   started = false;
   ended = false;
   index = 0;
MarkT
What you did is fail to read the documentation for bitRead!!
Replace this section of loop()
      Serial.println(b);
      if((b&bit(j))>0) {
        AD[j]=HIGH;
      else {
        AD[j]=LOW;
      delay(100);
by the succinct:
      digitalWrite (AP[j], bitRead (inInt,j));  // extract relevant bit and output on relevant pin.
alkopop79
MarkT
Yes, the bitRead() function returns 1 or 0 (a single bit, already shifted appropriately).
BTW digitalWrite () treats any non-zero value as HIGH, (LOW is the same as 0 is the same as false), so you often don't need
to convert values specifically to HIGH or LOW - just pass directly to digitalWrite.
alkopop79
#4
Dec 10, 2012, 07:16 pm Last Edit: Dec 10, 2012, 08:20 pm by alkopop79 Reason: 1
Thank you, that's a very good point! I'm having trouble with the control flow again. This time a for loop gets executed continuously (as it's supposed to) but cannot make it run only once. Tried the break statement with no success.
char addressBit[10];
char dataBit[6];
int arrayIndex, dataIndex,i;
boolean startedA, endedA, startedD, endedD = false;
int CE  = 47;
int OE  = 48;
int WE  = 49;
int AP[13] = {22,24,26,28,30,32,34,36,38,40,42,44,46};
int DP[8] =  {23,25,27,29,31,33,35,37};
void setup(){
 Serial.println("Enter address in decimal starting with the letter a and finishing it with a period!");
 Serial.println("Then enter data in decimal between d and comma!");
 for (i=2;i<10;i++) {
   pinMode(AP[i],OUTPUT); // address pins
 for (i=9;i<14;i++) {
   pinMode(DP[i],INPUT); // data pins
 // Setup Control Pins
 pinMode(CE, OUTPUT);
 pinMode(WE, OUTPUT);
 pinMode(OE, OUTPUT);
 pinMode(45, OUTPUT);
 // Setup Chip
 digitalWrite(CE, HIGH);
 digitalWrite(WE, LOW);
 digitalWrite(OE, HIGH);
void loop(){
 digitalWrite(45, HIGH);
   if(aChar == 'r') //beginning of the string
     startedA = true;
     arrayIndex = 0;
     addressBit[arrayIndex] = '\0';
   else if(aChar == '/') ///end of string
     endedA = true;
   else if(startedA)
     addressBit[arrayIndex] = aChar;
     arrayIndex++;
if(startedA && endedA){
   int incomingByteA = atoi(addressBit); // Convert the string to an integer
   for(int j=0; j<13; j++){
     digitalWrite (AP[j], bitRead (incomingByteA,j));  // extract relevant bit and output on relevant pin.
     int a = bitRead (incomingByteA,j);
     Serial.println(a);
   startedA = false;
   endedA = false;
   arrayIndex = 0;
  delay(1);
   digitalWrite(WE,LOW);      // Write Disabled
   delay(1);
   digitalWrite(CE,HIGH);      // Chip enabled
   delay(1);
   digitalWrite(OE,HIGH);       // Reads Enabled
   delay(1);
for(int i=0; i<8; i++){       /// FOR LOOP
 int DD = digitalRead(DP[i]);
 Serial.println(DD);
 delay(100);
It's the last bit that gives me headache:
 Serial.println(DD);
It seems that this bit prints whatever is coming from the serial as opposed to print the state of the pins. Where did I go wrong? Any suggestions would be appreciated!
alkopop79
I cleaned up the code a bit and still get strange results on the serial monitor.
char addressBit[15];
char dataBit[10];
int arrayIndex, i;
boolean startedA, endedA, flow = false;
int CE  = 47;
int OE  = 48;
int WE  = 49;
int AP[13] = {
int DP[8] =  {
void setup(){
  // Setup Chip
void loop(){
      startedA = true;
      arrayIndex = 0;
    else if(aChar == '/') //end of string
      endedA = true;
    else if(startedA)
      arrayIndex++;
  if(startedA && endedA){ // string filled up
      //Serial.println(a);
    startedA = false;
    endedA = false;
    arrayIndex = 0;
    delay(1);
    delay(1);
    delay(1);
    int data = digitalRead(DP[i]);
    Serial.print(data);
  delay(300);
Anyone could verify if it works? Just looking at the serial monitor doesn't help. Still struggle with that last for loop, I wish I knew how to execute it one!
PaulS
bool doItThisTime = true;
   // some stuff to do every time
   if(doItThisTime)
      // some stuff to do once
      doItThisTime = false;
Printing numbers to the serial monitor is an exercise in frustration unless you label them.
a != r!
alkopop79
I tried what you suggested and now it won't work. What did I do wrong?
char dataBit[10];
int arrayIndex, i;
boolean startedA, endedA = false;
boolean once = true;
int CE  = 47;
int OE  = 48;
int WE  = 49;
int AP[13] = {
int DP[8] =  {
void setup(){
  // Setup Chip
void loop(){
      startedA = true;
      arrayIndex = 0;
      endedA = true;
    else if(startedA)
      arrayIndex++;
    startedA = false;
    endedA = false;
    arrayIndex = 0;
    delay(1);
    delay(1);
    delay(1);
if(once){
    Serial.print(data);
  once = false;
  delay(300);
alkopop79
a != r!
Not sure what you meant by that. Can you explain that please?
PaulS
It's more what you failed to do. That is, you failed to put each { on a new line. You failed to use Tools + Auto Format to fix the indenting.
Code that bounces
            all over the place is
    very hard to read. The
        Tools + Auto Format
menu item
                           fixes that problem.
Sure. The message you print says that the text entered should start with an a. The code expects the text to start with an r. An a is not equal to an r.
alkopop79
Oh, cr*p, I copied it from an other sketch. Makes sense. Thanks you!
alkopop79
Code that bounces
        Tools + Auto Format
menu item
                           fixes that problem.
I do use Auto Format it's just I can't stand the bracket taking up an extra line. Never thought it can be a problem.
PaulS
Really? And it did this?
    delay(1);
    delay(1);
    delay(1);
if(once){
    Serial.print(data);
  once = false;
alkopop79
I appreciate your help and am grateful but I feel a but uncomfortable with your schooling.
PaulS
OK. I'll knock it off. The only reason I harp on this issue is that I feel that lining up the { and }, and doing consistent indenting, reveals a lot of issues with out-of-order execution and "why isn't his happening here" types of problems.
I suspect that that is why your print statements don't seem to be executed, but because nothing lines up, the only way for me to know that is to copy and paste your code into the IDE, put each { on a new line, and use Tools + Auto Format.
