Loading...
Pages: [1]   Go Down
Author Topic: SD data logging stops (8x8 matrix)  (Read 257 times)
Offline Offline
Newbie
View Profile
Hi there,
I´ve got a touch sensitive matrix from 8 rows and 8 columns using conductive threads and Linqstad Piezo film as a middle layer. The idea is to sense touch on objects.
Works fine but I have problems with storing the reading on a micro SD card. I am using a Mega R3 and Ethernet Shield R3 and an ScanDisk Micro SD card (FAT16).
Pin connection is a followed: rows connected to analog pins (0-7) and columns to digital pins (0-7) and I´ve got the Ethernet shield connected through the ICSP pins,
and pin 4 (SDCS) to dig pin 4 on the mega and pin 10 (shield) to pin 53 on the mega.
Problem is the reading stop until I press reset on the Shield. Then reading start again for one to 10 lines, then stops again and so on.
I need to have the reading running constantly to be saved a single file on the sd card.
The readings look like this:
Initializing SD card...card initialized.
421,449,1023,466,420,472,464
422,1023,467,963,444,472,1023
419,1023,1023,465,543,471,463
1023,1023,469,470,411,482,476
415,1023,465,467,846,1023,1023
413,444,1023,465,934,476,471
408,439,1023,460,612,469,464
1023,1023,452,451,714,1023,1023
959,404,413,414,834,421,1023
380,405,1023,1023,547,422,418
Can anybody help me with that?
I attach the data logging sketch.
Thanks,
das auryn
Logged
Brunsbüttel, SH, F.Rep.GERM
Offline Offline
God Member
View Profile
WWW
Hi!
What if u dont open the SD file and just print the result to the serial port?
Why do u read just 7 of those 8 analog pins?
Have fun...
Logged
-Arne
Pages: [1]   Go Up
Print
Jump to:
