Loading...
Pages: [1]   Go Down
Author Topic: writing digitalread states as bits  (Read 259 times)
Offline Offline
Newbie
View Profile
I just want to print to the serial every digitalread bit I catch.
How to do that ? How to use a buffer to do that ?
Thanks
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
How to do that ?
Code:
int digitalReadBit = digitalRead(theRightPin);
Serial.print(digitalReadBit);
Quote
Code:
int buffer[1];
buffer[0] = digitalRead(theRightPin);
Serial.print(buffer[0]);
Though why you want to use a buffer is a mystery.
Logged
Offline Offline
Newbie
View Profile
that way i would print on the serial a bit as a byte.
Am I wrong ? I want raw bits
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Well, don't cook them.
What do you mean? The digitalRead() function returns an int, whose values are either 0 or 1. That looks like bits to me.
Logged
Offline Offline
Newbie
View Profile
if you Serial.print(0) it should give 00110000, not 00000000
instead I want:
byte = read_8_bits()
Serial.print(byte)
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
How do you figure that 0 is 110,000? If that value is binary, the decimal equivalent is 48, which, coincidentally enough, just happens to be the ASCII code for a 0.
So, if you print '0' like so:
Serial.print('0', BIN);
you will get 00110000.
But that has NOTHING to do with raw bits from digitalRead().
Logged
Offline Offline
Newbie
View Profile
I guess. From the manual:
Serial/Print: Prints data to the serial port as human-readable ASCII text.
If digitalRead(mypin) is == 0 then:
print somehow to the serial a 0 bit
if digitalRead(mypin) == 1 then:
print somehow to the serial a 1 bit
That's what I need. I hope i explained it better.
Thanks
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
Serial.print(byte)
Trying to print the name of a datatype is going to give you problems.
Quote
Code:
Serial.print ((byte)digitalRead (mypin));
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
instead I want:
Serial.print(byte)
Perhaps you mean you wish to read and print out AVR I/O ports that can contain up to 8 bits?
as in:
Code:
int portByte = PIND; //Read AVR port D bits which correspond to arduino pins 0-7 on a 328 based board
Serial.print(portByte, BIN);
http://playground.arduino.cc/Learning/PortManipulation
Lefty
« Last Edit: December 10, 2012, 04:23:18 pm by retrolefty » Logged
UK
Offline Offline
Tesla Member
View Profile
I want raw bits
I'm not clear what format you're trying to output, but if you want to output binary data instead of ascii characters then you might want to look at write() instead of print().
If you want to collect eight digitalRead() results and pack them into a byte and then output that as a binary value then you need to use bitSet()/bitClear() or the equivalent bitwise operators to build the byte and then write that value out. I'm only guessing what you're trying to achieve, though, because you haven't actually said.
Logged
Saskatchewan
Offline Offline
Full Member
When the going gets weird, the weird turn pro. - Hunter S. Thompson
View Profile
Here's how I'm seeing the request
Code:
byte pinState = digitalRead(mypin);
if (pinState == HIGH)  Serial.println("1";
else Serial.println("0");
Shrug ...
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Would this work?
Code:
void setup ()
  Serial.begin (115200);
  }  // end of setup
void loop ()
  Serial.println (PINB, BIN);
  delay (1000);
  }  // end of loop
Logged
Offline Offline
Edison Member
View Profile
Very easy:
Code:
void sprintf_byte(unsigned char dat) {
  unsigned char mask = 0x80; //msb first
  do {
    if (dat & mask) Serial.print("1"); //print1
    else Serial.print("0"); //print 0
    mask = mask >> 1; //shift to the next bit
  } while (mask);
void sprintf_short(unsigned short dat_word) {
  sprintf_byte(dat_word >> 8); //printf msb
  sprintf_byte(dat); //print lsb
Logged
Pages: [1]   Go Up
Print
Jump to:
