Hvis du bruger denne core, får du muligheden for 16Mhz både med og uden krystal:
http://code.google.com/p/arduino-tiny/downloads/detail?name=arduino-tiny-0100-0015.zipDet har også den fordel at den er udviklet af Coding Badly her på forum, og han er meget hjælpsom hvis der er problemer.
Iøvrigt er de forskellige indstillinger et spørgsmål om at bruge de rette "fuses". De bliver automatisk sat når du bruger funktionen "Burn Bootloader"
Oplysningerne ligger i filen boards.txt
Hvis HLT coren ellers virker på samme måde kan du jo prøver at kopiere dette fra min boards.txt:
attiny85at16e.name=ATtiny85 @ 16 MHz (external crystal; 4.3 V BOD)
# The following do NOT work...
# attiny85at16e.upload.using=avrispv2
# attiny85at16e.upload.using=Pololu USB AVR Programmer
# The following DO work (pick one)...
attiny85at16e.upload.using=arduino:arduinoisp
# attiny85at16e.upload.protocol=avrispv2
# attiny85at16e.upload.using=pololu
attiny85at16e.upload.maximum_size=8192
# Ext. Crystal Osc.; Frequency 8.0- MHz; Start-up time PWRDWN/RESET: 16K CK/14 CK + 65 ms; [CKSEL=1111 SUT=11]
# Brown-out detection level at VCC=4.3 V; [BODLEVEL=100]
# Preserve EEPROM memory through the Chip Erase cycle; [EESAVE=0]
# Serial program downloading (SPI) enabled; [SPIEN=0]
attiny85at16e.bootloader.low_fuses=0xFF
attiny85at16e.bootloader.high_fuses=0xD4
attiny85at16e.bootloader.extended_fuses=0xFF
attiny85at16e.bootloader.path=empty
attiny85at16e.bootloader.file=empty85at16.hex
attiny85at16e.build.mcu=attiny85
attiny85at16e.build.f_cpu=16000000L
attiny85at16e.build.core=tiny
attiny85at16p.name=ATtiny85 @ 16 MHz (internal PLL; 4.3 V BOD)
# attiny85at16p.upload.using=avrispv2
# attiny85at16p.upload.using=Pololu USB AVR Programmer
attiny85at16p.upload.using=arduino:arduinoisp
# attiny85at16p.upload.protocol=avrispv2
# attiny85at16p.upload.using=pololu
attiny85at16p.upload.maximum_size=8192
# PLL Clock; Start-up time PWRDWN/RESET: 1K CK/14 CK + 4 ms; [CKSEL=0001 SUT=00]
attiny85at16p.bootloader.low_fuses=0xC1
attiny85at16p.bootloader.high_fuses=0xD4
attiny85at16p.bootloader.extended_fuses=0xFF
attiny85at16p.bootloader.path=empty
attiny85at16p.bootloader.file=empty85at16.hex
attiny85at16p.build.mcu=attiny85
attiny85at16p.build.f_cpu=16000000L
attiny85at16p.build.core=tiny
attiny85at8.name=ATtiny85 @ 8 MHz (internal oscillator; BOD disabled)
# attiny85at8.upload.using=avrispv2
# attiny85at8.upload.using=Pololu USB AVR Programmer
attiny85at8.upload.using=arduino:arduinoisp
# attiny85at8.upload.protocol=avrispv2
# attiny85at8.upload.using=pololu
attiny85at8.upload.maximum_size=8192
# Default clock (slowly rising power; long delay to clock; 8 MHz internal)
# Int. RC Osc. 8 MHz; Start-up time PWRDWN/RESET: 6 CK/14 CK + 64 ms; [CKSEL=0010 SUT=10]; default value
# Brown-out detection disabled; [BODLEVEL=111]
attiny85at8.bootloader.low_fuses=0xE2
attiny85at8.bootloader.high_fuses=0xD7
attiny85at8.bootloader.extended_fuses=0xFF
attiny85at8.bootloader.path=empty
attiny85at8.bootloader.file=empty85at8.hex
attiny85at8.build.mcu=attiny85
attiny85at8.build.f_cpu=8000000L
attiny85at8.build.core=tiny
attiny85at1.name=ATtiny85 @ 1 MHz (internal oscillator; BOD disabled)
# attiny85at1.upload.using=avrispv2
# attiny85at1.upload.using=Pololu USB AVR Programmer
attiny85at1.upload.using=arduino:arduinoisp
# attiny85at1.upload.protocol=avrispv2
# attiny85at1.upload.using=pololu
attiny85at1.upload.maximum_size=8192
# Default clock (slowly rising power; long delay to clock; 8 MHz internal; divide clock by 8)
# Divide clock by 8 internally; [CKDIV8=0]
attiny85at1.bootloader.low_fuses=0x62
attiny85at1.bootloader.high_fuses=0xD7
attiny85at1.bootloader.extended_fuses=0xFF
attiny85at1.bootloader.path=empty
attiny85at1.bootloader.file=empty85at1.hex
attiny85at1.build.mcu=attiny85
attiny85at1.build.f_cpu=1000000L
attiny85at1.build.core=tiny
