Loading...
Pages: [1]   Go Down
Author Topic: Guidance please for a Big Easy Stepper driver and 42BYGHM809 motor  (Read 517 times)
England
Offline Offline
Newbie
View Profile
I am currently trying to design a model railway turntable so that I can simply select an outgoing road and the turntable will consistently rotate and line up to outgoing tracks. I have purchased an Arduino Uno and am having fun relearning programming!
The motor I am looking at seems suitable in that it has 400 steps per rotation and a 5mm shaft to match the base of the turntable.
However I note that it is rated at 3v and 1.7A. As the Big Easy Board needs at least 7v to operate will it harm board or motor if I apply a 12v supply (basic voltage on the model railway)?
Whilst I am OK programming I am a bit lacking in my electronics knowledge! Any guidance would be appreciated.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
The Big Easy controller uses a chopper drive chip - this is fine with high voltage supplies, it automatically down-converts the voltage
like a buck switching regulator sa needed to provide the nominal current to the motor.  Make sure its set up for the current you want
and that the supply is well _above_ 3V.  The higher the supply voltage the faster you'll get the motor to move (overcomes back EMF at
higher speeds).  The higher the supply voltage the less current it will need (at slow speeds at least) due to the automatic switching
regulation.
However for your application speed is clearly not an issue - in fact torque will be and reduction gearing might be more useful.  At least
that motor is pretty powerful and the microstepping ability of the controller will be useful.
Note that at the full 1.7A it will run hot - a small fan or a heatsink is recommended in this case.  Consider reducing the current when
the turntable is parked.
(PS  its good form to include links to all devices you mention, such as http://www.schmalzhaus.com/BigEasyDriver/ http://dlnmh9ip6v2uc.cloudfront.net/datasheets/Robotics/42BYGHM809.PDF
Logged
England
Offline Offline
Newbie
View Profile
Many thanks - I hoped that was the answer smiley
ps - will do in future
Logged
Pages: [1]   Go Up
Print
Jump to:
